HP 460 G4 boot loop restart
  • Askic
    • Sep 2018
    • 187
    • BIH
    I have HP 450 G4 laptop with DA0X83MB6H0 motherboard that is stuck at boot loop restart.
    When powering ON, firste there is a dealy about 10 sec before showing HP logo and then after 15 to 20 sec it restarts itself.
    If I try to enter BIOS (with F10) or Sys diagnostic (F2) there is a message "Entering Setup" or "Entering diagnostic" and after 20 sec restart.
    I have tried with different BIOS dumps, exchange RAM modules remove/short CMOS battery and many more, but it didn't change behavior.
    Keyboard is working since it detects function keys. If I place another RAM module, after first power ON I can see a message "Amount of RAM changed", and that stays for about 20 sec and new restart.
    So basically, it is stuck at boot loop before it is possible to enter BIOS settings.
    There is a problem on the board, but don't know from where to start. Did you have any similar experience?
    Thank you
  • peste
    • Dec 2016
    • 13022
    • ROMANIA
    Re: HP 460 G4 boot loop restart
    There is a problem on the bopard, but don't know from where to start. Did you have any similar experience?
    Thank you
    post the bios backup in the section
    "BIOS Requests ONLY!" ...
    • Askic
      • Sep 2018
      • 187
      • BIH
      I'm almost certain this is not a bios issue. I have the same board which works and I even solder its BIOS chip but it behaves the same. I even swap the BIOS chips. The issue is something with the motherboard.
      For example when measuring resistance against the ground on PL22 it is 4 ohms, while the same resistance on the correct one is about 11 ohms.
      Interesting, I cannot measure any voltage on this coil on both boards, but one board works fine.
      The only difference I could find so far it this resistance, but it is expected to be low, since it is CPU area.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try replacing PC262/276/279
        • Askic
          • Sep 2018
          • 187
          • BIH
          Those are big electrolytic caps. Do you suspect that their resistance has changed?
          What DC voltage on this PL22/ caps is to be expected, 0.9V??
          • Askic
            • Sep 2018
            • 187
            • BIH
            Here is that part of the power supply in which I cannot measure any voltage. I can measure VIN to be 19.5V. Without power, resistance between Drain and Source of PQ10 low side MOSFET. I have taken it out and between pins there is still 4 ohms and PQ10 is good.
            I would normally expect to measure here around 1 V, but there is nothing there. I must say, that this is probably not the issue because I have picture on the screen and HP logo for about 20 sec.
            • piernov
              • Jan 2016
              • 4437
              • France
              You know you can't just swap SPI ROM between boards because ME region is paired with the PCH right?
              • Askic
                • Sep 2018
                • 187
                • BIH
                yes and I wrote in the first post that I have tried different BIOS dumps. I even used cleaned BIOS dumps from one forum. However, I’m really not sure why behaviour is like that to restart laptop after 20 sec. When different ME region laptop usually works very slow, but not restart after the same time period. It detects function key F10 and there is a message Entering Setup... and after that new restart.
                Do you think that problem is likely related to BIOS/SPI ROM issue than hardware? I must admit I have never had this behaviour.
                I know these are typical symptoms of mismatch Between ME region in BIOS software and PCH:
                1. If ME Region Get Corrupted In Most Cases The System Will Start At Least, But Not Total Dead.
                2. Fan Spinning At 100% Full Speed.
                3. Random Shutdow at Regular Interval ( Say 1min, 30min, even 1 Hours…).
                4. When Facing Problem With Reboot Seems ME Region May Corrupted.
                5. Corrupted ME Region May Cause Hanging Problem.
                6. Somtimes Corrupted ME Region May Cause Spalsh Screen.
                7. Corrupted ME Region May Cause Slow Down System Performence.
                So there is a reboot/shutdown at regular intervals, but in all cases so far, I could at least enter setup or no start computer at all.
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  I was referring to:
                  and
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yes , 0.9V seems ok to me. Electrolyte caps loose their capacitance over time-thats why try replacing them.
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • q2v5
                      Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                      by q2v5
                      Lenovo T480s
                      Model 20L8-S3TE00
                      Board ET481-U10
                      Chip MX25L12873F
                      Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                      2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                      The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                      08-15-2024, 10:40 PM
                    • NolesFan
                      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                      by NolesFan
                      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                      10-24-2024, 06:36 PM
                    • Max029
                      Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                      by Max029
                      I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                      I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                      TY,
                      08-18-2024, 08:28 PM
                    • eltano4i20
                      [HELP] SAMSUNG NP270E4E-K01AR
                      by eltano4i20
                      1) Error trying to enter the BIOS
                      --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                      Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                      BOOT PRIORITY ORDER (img-05)
                      1- Windows Boot Manager
                      2- SATA HDD
                      3- NETWORK
                      4- Debian
                      2) Error trying to access the BOOT MENU
                      --> I restarted the notebook and pressed [F10] but the BOOT...
                      07-04-2025, 12:39 AM
