lenovo ideapad 110 15isk
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    lenovo ideapad 110 15isk - no battery detected
  • peste
    • 13573
    • ROMANIA
    Re: lenovo ideapad 110 15isk
    https://www.badcaps.net/forum/showthread.php?t=90356
    • mrkmpn
      Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
      by mrkmpn
      Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
      This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
      03-13-2024, 01:54 PM
    • pabloroggeri
      Lenovo V310-15ISK - It doesn't work after changing the battery
      by pabloroggeri
      Good guys. I changed the battery to a Lenovo V310-15ISK.
      The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
      When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
      08-23-2024, 12:01 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
    • ZixuTech
      Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
      by ZixuTech
      Hi Guys, a weird case here.
      This laptop came with damaged hinges, but no liquid signs.
      It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
      I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
      I have replaced bq24780S battery charging chip, no difference.
      With a connected new battery,...
      04-03-2022, 04:03 AM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
