A1466 820-00165 No Power
  • mon2
    • Dec 2019
    • 14662
    Hi. Have an A1466 820-00165 unit with no power / no fan / no chime. Magsafe light goes green / orange cycling. No liquid damage indicators, looks quite clean and not serviced by anyone (yet).
    Found that there is no PPBUS_G3H rail. Then noted that 8A fuse @ F7140 is blown. Fuse Pin 1 @ 8v6; Pin 2 @ 0v. That fuse arrived yesterday (Belfuse Fast Blow @ 8A). Replaced with great excitement but now, the rail is about 0v5v and the fuse is still intact.
    Have removed the wifi card; removed the SSD; removed the battery. Swapped out the DC / audio board with another - no difference.
    Do feel some warmth around L7130 but do not (yet) own a thermal camera.
    Any ideas?
    Suspecting that something after the PPBUS_G3H is causing excessive current draw and this power supply (U7100) is shutting down.
    Bad cap downstream?
    Also, a bit confused on what is the expected power rail here. This chassis has 8v6 for PPBUS_G3H (thanks Piernov for the clarity - schematic is not accurate) - when the fuse was OPEN. Yet another tech posted for the same logic board, they have 12v6 on this rail. Can remove the fuse again to confirm that U7100 is still good.
    With the new fuse (8A) installed, see 16.xx volts (from magsafe) @ R7005 and this is feeding into the buck converter for the 3v42 rail just fine. But R7006 is @ 0v5 (PPBUS_G3H).
    Welcome suggestions. We did recently purchase the Sunshine voltage injector but honestly afraid to use it. Also brought in some of the 'smokey flux' they show in their demos.
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: A1466 820-00165 No Power
    All airs has 8.6v on ppbus_g3h. 12.6v is on macbook Pro's.
    How many ohms to ground on ppbus_g3h? Fuse blow because of reason, i bet that something is shorting ppbus. Check ohms, after that inject 1v to ppbus and check how many amps it is using. one of caps probably will be shorted and will go hot. tou can feel that with fingers. Make sure that ppbus would use about 3 wats, then it is easy to feel hot spot .
    • mon2
      • Dec 2019
      • 14662
      Awesome - thank you so much for your comments. Will remove the fresh fuse, confirm that the PPBUS_G3H power supply is still working (very confident that it is). Then will break open the Sunshine tool - was looking forward to using this gadget Will report back.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        A blown fuse on a MAC Book!? That's almost unheard of!!! Jokes aside, as mentioned by zpi, its most likely a short somewhere on that line. Before injecting voltage, do a visual inspection first. Check for cracks on the bigger black caps or the small smd brown caps (the small ones usually discolor and might be greyish brown.
        If you cant find anything visually, then inject voltage and feel for heat spots. As mentioned, start not more than 1V 1A, then gradually raise the current. I usually start at 0.8 - 0.9V in case its a shorted high side mosfet connected to CPU.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          Firstly just measure ppbus to ground in ohms.
          • mon2
            • Dec 2019
            • 14662
            0.217 to 0.25 ohms @ smd fuse to ground.
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              So its dead short, inject 1 voltage and find hotspot, let us know how many amps ppbus is drawing when 1v is injected.
              • mon2
                • Dec 2019
                • 14662
                Hi. Have the Sunshine TS-30 tool here which I believe is fixed to output @ 30A?
                Dialed up to 1.0v which is about 0.95-0.98v according to our 6 digit VM which I trust more than this injector.
                With black to ground; red probe of injector to the PPBUS_3v3H pin (no fuse), see a spark upon mating and values like 3A-8A but I am removing it after a pulse of this energy.
                Should we keep the voltage on for a long period?
                Now that the fuse is removed for this testing, the PPBUS_3v3H is @ 8v6 at the switcher power supply.
                • mon2
                  • Dec 2019
                  • 14662
                  Almost ready to celebrate with non-alcoholic drinks...placed some alcohol onto assorted tantalums and applied the probes (TS-30A) - saw the alcohol evaporate on one of the caps. Two of us saw the same cap heat up and dry up very quickly. Removed this single cap and now see a resistance of 20k or so
                  Will apply the fuse back on and report back.
                  So so so exciting. Knowledge is KING. Thank you again.
                  • mon2
                    • Dec 2019
                    • 14662
                    Hi. Ok, attached the DC / Audio board and if the large L-shaped flat cable is NOT connected, the logic board is spinning the fan This is very positive.
                    I am pretty sure that the video will work but have not yet attached the LVDS cable but will do so before leaving for the evening.
                    If we attach the L-shaped cable - the fan does NOT spin.
                    Any idea on what could be cause? We do have a known-good DC board in transit from Shenzhen but thought we could use this unit to fix another which has the same issue - the fan will not spin with L-shaped cable. Now have 2 logic boards like this. Both need fresh dc/audio boards?
                    • mon2
                      • Dec 2019
                      • 14662
                      Attached the video cable - the machine works!!!!!! Have a login screen.
                      The L-shaped cable is OFF. Will try with it on. Could it be that we have the keyboard disconnected?
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Needs a genuine Apple Magsafe2.
                        • mon2
                          • Dec 2019
                          • 14662
                          Hi piernov. Thank you for your feedback. So the external power adapter is causing the grief that we are bypassing by removing the L-shaped cable?
                          Wow. Honestly do not know the history of this external adapter.
                          Funny enough, studying the single wire protocol that is used by Apple for the hand-shake. More on that later.
                          Will search for a better external adapter.
                          Thank you!!
                          • Spider1211
                            • Oct 2019
                            • 532
                            • Mauritius
                            Might also be worth checking if there is any bent pins/debris on the connectors.
                            • mon2
                              • Dec 2019
                              • 14662
                              We had another adapter but been informed that all of our adapters are original. Apparently bought from Apple online. The 2nd adapter after 2-3 attempts, powers on the unit WITH the L-shaped cable attached. Will keep testing. Thanks.
                              • mon2
                                • Dec 2019
                                • 14662
                                For future readers, it was C7584 (tantalum) that was heating up and was causing this short-circuit event. Will order some fresh ones from Arrow.
                                • Nagy Daniel
                                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                                  by Nagy Daniel
                                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                  So, I generated a table with AI so I can...
                                  03-04-2025, 08:24 AM
                                • junda
                                  MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off)
                                  by junda
                                  hi, i also have the same (P5V_S4RS3) MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off) The strange thing is when I kept machine for 1 day and connect the power It powers on with Chime and booots half way with Apple logo and stuck. at that time when I power of and try power up Fan spins for few seconds and goes off with no P5V_S4RS3 and also the P5V_S4RS3 EN pulses on and off with 3,24 V. Plezzz doesn any one can help me
                                  08-26-2024, 09:54 AM
                                • corrize
                                  A funny fuse story – Lumix LX100 II
                                  by corrize
                                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                  10-19-2023, 09:58 AM
                                • Victor Moreira Silva
                                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                  by Victor Moreira Silva
                                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                  Well, my decice specs are the following:
                                  Model: Acer Nitro 5 AN517-54-55T5
                                  CPU: Intel Core i5-11400H
                                  GPU: NVIDIA GeForce GTX 1650
                                  Motherboard: GH51G LA-L181P Rev:1c
                                  The symptom:
                                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                  05-26-2025, 10:49 AM
                                • lefetylorant
                                  Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                  by lefetylorant
                                  Hello Everyone,
                                  Long story short, I got this unit for very cheap.
                                  I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                  I've performed some measurements:
                                  - 20V rail perfectly...
                                  09-14-2023, 05:05 AM
