Dell G7 LA-E994P not start after water spill
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Have this Dell G7 LA-E994P that after water spill and cleaning did not start.
    It was get to me from other shop that clean corossion, but i dont know where.
    Board have 3.3V, 5V, 1.0V, 1.8V but no RAM, CPU, GPU power and on GPU coils i measure 0.2ohm to ground, but even after removing gpu coils nothing changed. power switch works ok, but i try to measure which pin on KBC is PWSW but cannot find it
    Dont have schematic
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Dell G7 LA-E994P not start after water spill
    0.2Ohm are very very low. You measured on which side is the short after removing the coil? What did you tried, to convert it to UMA?
    FairRepair on YouTube
    • piernov
      • Jan 2016
      • 4439
      • France
      Resistance to ground lower than 1 ohm is normal on VCore of NVidia 1000 series and newer. Hard to say what's actually a short to ground and what's not.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        PIN127 of kbc is power sw_in and there is no power button on this kbc. You need to trace the resistor connected to pin 127 of kbc. The other side of the resistor is power button and powerbutton on this mb is powered by RTC.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          this is ok. have 3V and it goe to 0 whe press PWBTN. so i must try to flash bios
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            after flash still no reaction on power button
            • Weelcup
              TopTech
              • Oct 2017
              • 307
              Is the laptop charging the battery?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                NO. have 0.2V on battery. data lines have 3.3V
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  do u thing that KBC is bad?
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    this is sad. i dont want to give up on this 1060gtx beast
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • estabilito
                      Dell Latitude E5590(La-f411p) water damaged
                      by estabilito
                      I have water damaged Dell Latitude E5590 around charging ic.
                      Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
                      I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
                      I dont have battery so i want to be sure if laptop behaviour is normal before buying.
                      On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
                      Is this voltage on pl902 normal?...
                      03-08-2025, 06:22 PM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                      by sam_sam_sam
                      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                      04-09-2023, 08:04 PM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
