Toshiba P55W Battery peekaboo
  • swofra
    • Jun 2020
    • 25
    • usa
    Hello all,
    Toshiba P55W-C5314 with a PA5208U-1BRS battery. Worked fine for months until a couple of weeks ago. Laptop will not turn on using battery power. However, powers on fine with AC power. Battery shows 100% charged via battery icon displayed in the bottom right corner and also by running BatteryReport so it seems to be recognized in some way - yet the battery charge status light on the case does not illuminate so maybe it doesn't?
    I've tried the uninstall battery method and it didn't work. Neither did leaving it plugged in to trickle charge. I tested the power at the battery connection point on the motherboard. With battery attached but AC adaptor not plugged in, I only got one reading: pin 7 at 3VDC. With the AC adaptor plugged in and the battery attached I got readings on pins 3 and 4 of 2.7VDC, pin 5 at 0.4, pin 7 at 3 and pins 8 & 9 at 0.7VDC. Worried that its a mobo problem vice a battery problem but looking for any suggestions. The battery is labeled 10.8V so if I'm measuring correctly at the right spot (see pic) and in the right manner (black probe touching metal, touch red to each pin to get the reading) it doesn't seem to get close to that.
    Thanks in advance!
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Toshiba P55W Battery peekaboo
    Voltage on pin 6 which is SDA=?
    Pin 7 is SCL 3v seems ok
      • 20888
      If thats the original battery its 5-6 years old. Install batterymon software, click on the small battery icon and post a screenshot like the one attached
      • swofra
        • Jun 2020
        • 25
        • usa
        Thanks for the responses. I am back from vacation.
        To answer questions thus far:
        Pin 6 I wasn't able to get detect any DCV using the procedures and counting pin positions described in my original post
        Attached is the BatteryMon. I can't get a reading on battery power as the laptop immediately shuts off as soon as the AC plug is pulled.
        Thanks!
        • swofra
          • Jun 2020
          • 25
          • usa
          What voltage should normally be going to the battery (when charging it) and is it on a typical/standardized numbered pin 9 (e.g. the 1st, 4th, etc)? Does the lack of readings on a particular pin indicate it could be a ground pin?
          Lastly, I imagine that the battery wouldn't discharge the 10.8v unless the laptop was drawing it...but in my checks with the multimeter I never got close to 10.8. If I removed the battery from the laptop, the connector for the battery was too small to fit the probe - haven't tried with a thin wire yet unless that could yield some important diagnostic information.
          Thanks in advance!
          • piernov
            • Jan 2016
            • 4435
            • France
            Not sure what you are trying to do… when you have a dead battery you replace the battery, no point in messing with the software or hardware.
            • swofra
              • Jun 2020
              • 25
              • usa
              BatteryMon and another battery analysis tool shows that the battery is still at ~75% of its design capacity and 100% charged, that is why I want to make sure its not something on the mobo before I shell out the money for a new battery.
                • 20888
                BatteryMon is reporting a wierd number of charge cycles.Test all the mosfets around the battery connector area.
                • swofra
                  • Jun 2020
                  • 25
                  • usa
                  What is the best way to do this without having to remove any from the circuit board? There's a lot of varying techniques I've seen, is there a video that describes how to do it best/most effective?
                  Thanks!
                  • swofra
                    • Jun 2020
                    • 25
                    • usa
                    Any guidance on the above? Wife has set a deadline by the weekend that she needs the computer to work on battery power and cheapest replacement battery I can find is $40 ... trying to avoid shelling out that kind of cash if it might be something on the mobo.
                    • Shinju
                      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                      by Shinju
                      Hey All!
                      Long time forum member here with a problematic laptop issue!
                      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                      The laptop would not power on with the new battery installed without the power supply being plugged in.
                      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                      10-20-2021, 04:58 PM
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • techfreak9356
                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                      by techfreak9356
                      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                      09-14-2023, 11:10 PM
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • huzo
                      HP ELITE X2 1013 G3 weird battery issue
                      by huzo
                      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                      01-31-2025, 12:09 AM
