Can anyone identify this mosfet?
  • Willaraz
    • May 2013
    • 14
    • Greece
    I'm trying to fix this Dell 2205 AIO, the screen doesn't come on and I suspect the motherboard isn't supplying 12v to the inverter. Although I may be wrong.
    What is TRF with a value of E and apparently the dot means its led free?
    I also put a little schematic thing up, I don't know if it's helpful.
    I posted this under Laptops, Portable, and Mobile Devices because of the external power brick and the motherboard felt more like a laptop one.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Can anyone identify this mosfet?
    It is a load switch mosfet used in video device where sensing signal is required
    Google TRF mosfet you will find it at second page
    Although it is TRF m p channel
    Onsemi.com make these
    But they are two types p channel and n channel so check which one you have
    P channel conducts drain to source but not backwards
    N channel conducts source to drain but not backwards
    Three leg mosfet
    If you have schematic , first check number on it motherboard starting Q and find it in schematic
    • Willaraz
      • May 2013
      • 14
      • Greece
      I also found the pdf but didn't understand what was going on, thanks for clearing up for me!
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        If n channel then mosfet conducts when gate valve is higher than source
        Vgs high= vg- Vs= 17-19= -2 wrong
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • tmaster21
          Ideapad 100 NM-A841, P channel mosfet on laptop in.
          by tmaster21
          Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
          Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
          07-17-2023, 09:48 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • armands0212@gmail.com
          Can someone help identify this mosfet marked GAF ?
          by armands0212@gmail.com
          This mosfet is from surface 2 go and if i try power it on this is only component what is heating.cant find schematics to identify this mosfet so maybe someone can help?
          Thanks...
          10-01-2023, 12:48 PM
        • Tarot Superstars
          Reading N-Channel Mosfet Junctions (1N65)
          by Tarot Superstars
          Hi.
          I have a Mosfet in a power adaptor circuit and I want to know what is the Gate, Drain and Source.
          I have a data sheet and it shows which is the gate (#1) and I assume 2 and 3 are Drain and Source.
          But when I read it with a multimeter I read that it's likely not that.
          It seems to show that wire 3 is the gate and the other two are drain and source.
          I want to know because I want to design tests on the mosfet to see if it is broken.
          However, the gate of U1 (the pulse width modulator) is connected to wire 1 indicating it IS the gate...
          09-27-2023, 01:46 PM
