How to recover files form a A1466 macbook
	Tags: None
Re: How to recover files form a A1466 macbook
Hi there you can try this.
€ 1,77 24%OFF | M.2 NVME SSD Converteren Adapter Card voor MacBook Air Pro Retina 2013-2017 NVME/AHCI SSD Verbeterde Kit voor A1465 A1466 A1398 A1502
https://a.aliexpress.com/_mtcZ0Z3
Best regards
Steve -
it wont fit because of its pins sir im looking something that will fitHi there you can try this.
Best regards
SteveComment
Sorry I must read the question wrong this what you need is something like this
https://www.allekabels.be/delock/633...xoCICgQAvD_BwE
Or this
€ 7,52 50%OFF | Usb 3.0 Ssd Behuizing Voor 2012 Apple Macbook Air A1465 A1466 Ssd Externe USB3.0 Hub Opladen Converter Usb C adapter
https://a.aliexpress.com/_msFPLvB
€ 11,41 10%OFF | 18 + 8 Pin SSD naar SATA 2.5 inch USB Adapter Card voor 2012 Macbook Air/Pro Retina Converter met USB 2.0 Kabel
https://a.aliexpress.com/_mNpxJCH
Best regards
SteveLast edited by Stevedb; 12-08-2020, 12:11 AM.Comment
it wont fit sirSorry I must read the question wrong this what you need is something like this
Or this
Best regards
SteveComment
And this one
Sintech 28pin to USB 3.0 Adapter for SSD SSD From 2013-2014 Macbook A1465 1466 A1398 A1502
https://www.amazon.com/Sintech-Exten.../dp/B0173OU4ZQ
Best regards
SteveComment
it will fit but i cant recover the files to a working pcAnd this one
Best regards
SteveComment
Hi then you need one with enclosure is expensive the other one you can use another adapter to convert tu us which I already show you.
https://www.amazon.com/gp/aw/d/B08B6..._t3_B0173OU4ZQ
Or this one
https://www.ebay.co.uk/c/21021811713
This one is with enclosure..
Best regards
SteveLast edited by Stevedb; 12-08-2020, 04:11 AM.Comment
Easiest would be to use another macbook. Stick it in there, attach external drive, copy files, later copy to destination PC.Comment
Luckily A1466 = 13" macbook air from 2013-2017. And that SSD fits on 11" 2013-2015 aswell.Comment
Most Macs from Mid 2013 to Mid 2015 can be used to read that SSD (excl. the DeadCPUBook 12"), they all use the same connector and are mostly compatible. MacBook Air and iMac 2017 too. iMac 21.5" won't have the connector if it only came with HDD originally though.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
			by kuba2102Hi. SSD is not being detected in Mac m2 and older imac. I tried 3 different external enclosures and non of them work. I tried the cheap one and then the expensive enclosure. The laptop is dead and had short on the board so unsure if the ssd is working. Need your opinion guys
SSD: mz-jpv128s/0a2
Jorkar External SSD Enclosure for MacBook Air/Pro 12+16 PIN08-13-2025, 04:33 AM -
			by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
			by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
			by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... -
			by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? - Loading...
