How to recover files form a A1466 macbook
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    Hi I have a 128GB SDNEP 655-1837C I cant find any adaptor to work and try to recover its files. Hope someone can give me a link where to buy this type of tool to recovery the files..
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: How to recover files form a A1466 macbook
    Hi there you can try this.
    € 1,77 24%OFF | M.2 NVME SSD Converteren Adapter Card voor MacBook Air Pro Retina 2013-2017 NVME/AHCI SSD Verbeterde Kit voor A1465 A1466 A1398 A1502
    https://a.aliexpress.com/_mtcZ0Z3
    Best regards
    Steve
    • kalilinux25
      • Mar 2018
      • 2084
      • ZAMBOANGA SIBUGAY
      Best regards
      Steve
      it wont fit because of its pins sir im looking something that will fit
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Sorry I must read the question wrong this what you need is something like this
        https://www.allekabels.be/delock/633...xoCICgQAvD_BwE
        Or this
        € 7,52 50%OFF | Usb 3.0 Ssd Behuizing Voor 2012 Apple Macbook Air A1465 A1466 Ssd Externe USB3.0 Hub Opladen Converter Usb C adapter
        https://a.aliexpress.com/_msFPLvB
        € 11,41 10%OFF | 18 + 8 Pin SSD naar SATA 2.5 inch USB Adapter Card voor 2012 Macbook Air/Pro Retina Converter met USB 2.0 Kabel
        https://a.aliexpress.com/_mNpxJCH
        Best regards
        Steve
        • kalilinux25
          • Mar 2018
          • 2084
          • ZAMBOANGA SIBUGAY
          Or this
          Best regards
          Steve
          it wont fit sir
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            And this one
            Sintech 28pin to USB 3.0 Adapter for SSD SSD From 2013-2014 Macbook A1465 1466 A1398 A1502
            https://www.amazon.com/Sintech-Exten.../dp/B0173OU4ZQ
            Best regards
            Steve
            • kalilinux25
              • Mar 2018
              • 2084
              • ZAMBOANGA SIBUGAY
              And this one
              Best regards
              Steve
              it will fit but i cant recover the files to a working pc
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                Hi then you need one with enclosure is expensive the other one you can use another adapter to convert tu us which I already show you.
                https://www.amazon.com/gp/aw/d/B08B6..._t3_B0173OU4ZQ
                Or this one
                https://www.ebay.co.uk/c/21021811713
                This one is with enclosure..
                Best regards
                Steve
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  @Kalilnux25 is it that what you need?
                  Best regards
                  Steve
                  • RethoricalCheese
                    • Mar 2013
                    • 1518
                    • Estonia
                    Easiest would be to use another macbook. Stick it in there, attach external drive, copy files, later copy to destination PC.
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Yes
                      That is the easiest way if you go another macbook air from the same generation. But is not always possible if you got no shop. Or the board repairing is also possible.
                      Best regards
                      Steve
                      • kalilinux25
                        • Mar 2018
                        • 2084
                        • ZAMBOANGA SIBUGAY
                        Great thanks to all Im very thankful on the fast response in the forum
                        • RethoricalCheese
                          • Mar 2013
                          • 1518
                          • Estonia
                          Luckily A1466 = 13" macbook air from 2013-2017. And that SSD fits on 11" 2013-2015 aswell.
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            Most Macs from Mid 2013 to Mid 2015 can be used to read that SSD (excl. the DeadCPUBook 12"), they all use the same connector and are mostly compatible. MacBook Air and iMac 2017 too. iMac 21.5" won't have the connector if it only came with HDD originally though.
