ASUS X555LD no backlight
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    hello
    motherboard not open to backlight. So, i checked to motherboard and see anx1121 epxlode and 26. pin is damaged. changed ic and fixed road. but still same problem. i tryed to panel another pc, working fine. can you give me an idea of what i should do?
    and motherboard is x555ld rev 3.1
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS X555LD no backlight
    You need to measure voltage at Screen connector.
    • Anethra
      • Dec 2018
      • 70
      • Turkey
      19v and 3.3v comes to panel if you want to learn this. 0 panel and 0 cable doesnt any change.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        This makes no sense in diagnosing a fault. You need to measure specific pins which are responsible for lcd backlit like, BKLON, LCDVDD,BKLEN etc.
        • Anethra
          • Dec 2018
          • 70
          • Turkey
          k. i check to connectors vled=19v, blenable=2.8 and blpwm=0v. I followed the path and its going to 26th pin (damaged) on ic. I repaired the path but I can't get any measurements from ic when I check directly and it was new ic. So is my ic broken?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            ANX1121 may be badly soldered or bad. Btw, I hate this ic as most of the ic sold as new are bad. I myself faced this on another asus. Could be for faulty PCH as well.
            • Anethra
              • Dec 2018
              • 70
              • Turkey
              i can just replace it and it works normally now. ty for help mcplslg123
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • dhenion
                Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                by dhenion
                I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                The original board was:
                ASUS X510UNR REV 3.0 A
                The replacement board is:
                ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                01-30-2024, 01:45 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • ktmmotocross
                Asus G513QE keyboard and backlight not working
                by ktmmotocross
                Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                08-08-2025, 06:29 AM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
