Dell E6430 power led always on, cannot turn off, nothing on screen
  • Andreasbest
    • Aug 2014
    • 1153
    • Hellas ( Greece )
    Hello!
    First i thought that this fault is the usual GPU that needs reballing.
    Then i noticed that when i plug the power adaptor to laptop the power LED get on immediately and never turns off even if i press the button for 10 seconds. Only way to turn it off is by unplugging laptop from power adaptor, so i thought that perhaps is a capacitor fault?
    Also nothing appears on internal or external screen.
    Photos and schematics attached.
    Thank you in advance!!
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Dell E6430 power led always on, cannot turn off, nothing on screen
    what voltages are missing on the coils and check all coils Diode mode & update ?
    • Andreasbest
      • Aug 2014
      • 1153
      • Hellas ( Greece )
      Sorry but i don't understand.
      Where exactly you want me to measure?
        • 20695
        All the large square grey coils,test voltage.Then with no power check resistance to ground.
        • Andreasbest
          • Aug 2014
          • 1153
          • Hellas ( Greece )
          Oh ok
          PL1000 1v short to gnd
          PL1001 1v short to gnd
          PL1300 19.56
          PL1301 3.3
          PL5 19.56v
          PL6 0v short to gnd
          PL701 0v short to gnd
          PL702 0v short to gnd
          PL703 0v short to gnd
          PL704 0v short to gnd
          PL705 0v short to gnd
          PL200 1.5v
          PL102 5v
          PL101 3.3v
          PL400 1v
          PL500 0v short to gnd
          PL600 0v short to gnd
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Those coils may not be shorted to ground. Measure resistance on them in "Resistance" Mode. Low resistance is ok on cpu/gpu coils specially if cpu is soldered onboard.
            • Andreasbest
              • Aug 2014
              • 1153
              • Hellas ( Greece )
              You are right
              PL1000 1v 6Ω
              PL1001 1v 6Ω
              PL1300 19.56
              PL1301 3.3
              PL5 19.56v
              PL6 0v 0.6Ω
              PL701 0v 3.6Ω
              PL702 0v 3.7Ω
              PL703 0v 3.8Ω
              PL704 0v 2.4Ω
              PL705 0v 2.4Ω
              PL200 1.5v
              PL102 5v
              PL101 3.3v
              PL400 1v
              PL500 0v 16.9Ω
              PL600 0v 15.8Ω
              Do you want to measure the coils that have voltage too?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                PL6 is ground man-no voltage is expected there.
                • Andreasbest
                  • Aug 2014
                  • 1153
                  • Hellas ( Greece )
                  I measured every coil just in case.
                  • Andreasbest
                    • Aug 2014
                    • 1153
                    • Hellas ( Greece )
                    Any ideas?
                    Perhaps a corrupted BIOS or not?
                    • SuperAman
                      • Dec 2018
                      • 119
                      Originally posted by Andreasbest
                      Any ideas?
                      Most likely a corrupted BIOS or Super IO controller.
                      • Andreasbest
                        • Aug 2014
                        • 1153
                        • Hellas ( Greece )
                        Fixed
                        It was indeed a corrupt bios issue.
                        Thank you all!
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • Chrissygizmo
                          by Chrissygizmo
                          02-10-2025, 12:33 AM
                        • spice_disc
                          Vizio TV M50-C1 reboot cycle and static on screen
                          by spice_disc
                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                          09-08-2024, 02:37 PM
                        • ipatch
                          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                          by ipatch
                          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                          08-24-2024, 02:36 PM
