dell 15 Battery not charging
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Hey Guys,
    i have a dell 15 not charging the battery .
    here is the voltage
    • 21948
    Re: dell 15 Battery not charging
    There must be 100 dell 15 models....
    Post the motherboard part number,and the schematic (or a link to it if its already posted) .
    • kadi144
      • Aug 2015
      • 690
      • algerie
      Originally posted by smdflea
      there must be 100 dell 15 models....
      dv15 cp uma mb
      10263-1
      48.4ip01.011
        • 21948
        Originally posted by Gnikosalalalal33
        dv15 cp uma mb
        10263-1
        48.4ip01.011
        schematic. https://www.badcaps.net/forum/showthread.php?t=34711 .Remove the mosfet and check it for short S/G/D
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Check charging/discharge mosfet first. IS the adapter recognised in bios setup??
          • kadi144
            • Aug 2015
            • 690
            • algerie
            with battery
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Didnt you read post#5
              • kadi144
                • Aug 2015
                • 690
                • algerie
                With no batery
                with batery
                • kadi144
                  • Aug 2015
                  • 690
                  • algerie
                  i have changed PU4501 AND PU4504 AND PU4503
                  AND I D'ont know if i change th BQ07A OR NO
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Dont change components randomly without finding the fault. I asked for psid measurement which you are yet to answer. This way nobody can help you.
                    • kadi144
                      • Aug 2015
                      • 690
                      • algerie
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        So do you mean problem solved or charger recognised but still not charging?? If still not charging ,measure charging IC pins voltage and post here.
                        • kadi144
                          • Aug 2015
                          • 690
                          • algerie
                          • kadi144
                            • Aug 2015
                            • 690
                            • algerie
                            here is charging IC pins voltage
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Your Measurements are incomplete and preety useless. Measure ACDET/ACOK/ACDRV/REGN pins.
                              • kadi144
                                • Aug 2015
                                • 690
                                • algerie
                                problem resolved after change BQ07A
                                thanks to all especially mcplslg123
                                • kadi144
                                  • Aug 2015
                                  • 690
                                  • algerie
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • lawrenceptrini
                                    Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                                    by lawrenceptrini
                                    Hi Guys,
                                    I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                                    The laptop is working fine with the adapter plugged in and also with a charged battery.
                                    Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                                    ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                                    loses its charge, it stays on 0%.
                                    Measurements taken
                                    Charging IC (ISL95522HRZ) 32 pins
                                    Voltage to ground with ac adapter only plugged in:
                                    1)...
                                    08-26-2024, 06:45 PM
                                  • Grucha98
                                    Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                                    by Grucha98
                                    Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                                    Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                                    09-09-2024, 11:22 AM
                                  • shatteredhalo
                                    Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
                                    by shatteredhalo
                                    I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
                                    At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
                                    08-20-2020, 09:45 PM
                                  • inkman
                                    Dell battery not charging
                                    by inkman
                                    Dell battery.
                                    7.4v
                                    Genuine dell charger.
                                    I have this dell battery thats been left on storage for long time
                                    and its not charging anymore inside laptop.
                                    Software aida 64 indicates battery has zero wear level,voltage at 2.8v.
                                    I am using it in dell computer it came with.
                                    When laptop is running, aida 64 indicates battery is not charging.
                                    I think battery is locked.Please help me revive this battery, it is in really
                                    nice condition.Any question please ask.
                                    08-28-2023, 06:18 AM
