Alienware M17x R4 no power, low resistance 5v/3.3v to GND
Re: Alienware M17x R4 no power, low resistance 5v/3.3v to GND
since dellxps has found that his board powers on with 19v on the power button, i don't think this is the issue, however i can try it if there are no other options.
@dellxps15 do you have voltage at PL10 and PL11 when in off state?Comment
check all 3.3-5 volt ic contact and pins before do anything, because i read u worked on that area.
on some post over i posted if u have 3.3 volt on mosfet near kbc...
read post #18Last edited by dellxps15; 09-24-2020, 11:10 AM.Comment
Yeah all contacts are ok, but i have all 4 fets off and both coils and caps, i'll first put those back since we figured that 15ohm is ok as the r3 board has 15ohm too,
I replied to #18 in #20Comment
Ok, I've put everything back together, the PQ7 is 19V just like you said.
Measurements on the PU4 are:
1: 0V
2: 0V
3: 2V
4: 2V
5: 0V
6: 0V
7: 0V
8: 3.3V
9: 4.54V
10: 0V
11: 0V
12: 0V
13: 3.13V
14: 2V
15: 0V (GND)
16: 19.5V
17: 5V
18: 0V (NC)
19: 0V
20: 0V
21: 0V
22: 4.54V
23: 0V
24: 0V
@dellxps15, i've checked the EC_ON line from KB930 at PQ62, all 3 pins measure 0V, does that sound ok?Comment
1: 0V
2: 0V
3: 2V
4: 2V
5: 0V
6: 0V
7: 0V
8: 3.3V
9: 4.54V
10: 0V
11: 0V
12: 0V
13: 3.13V
14: 2V
15: 0V (GND)
16: 19.5V
17: 5V
18: 0V (NC)
19: 0V
20: 0V
21: 0V
22: 4.54V
23: 0V
24: 0V
voltage on u36 ec bios ? near kbc
pin 1:3.3
pin2 1.2
pin3 3.3
pin4 0
pin5 1.3
pin6 0
pin 7 3.3
pin8 3.3Comment
Ok now here are differences:
U36
1: 0V (3.3V for you, this comes from FSEL KB930)
2: 0V (1.2V for you, this comes from FRD KB930)
3: 3.3V
4: 0V
5: 0V (1.3V for you, this comes from FWR KB930)
6: 3.3V (0V for you, this comes from SPI_CLK KB930)
7: 3.3V
8: 3.3V
basically all the pins coming from the superIO have different values :SComment
try with these bios and ec bios....
bios is u48
ec bios is u36
use same version a13 for both
https://www.badcaps.net/forum/showthread.php?p=991153Comment
I've been busy with cousin's Clevo laptop not powering on anymore, i'll open a separate thread for that, i'm in the process of reprogramming the chips to A13 versions, i'll update you shortly about any changes.Comment
@dellxps15
lol can't believe it, the A13 worked... it's odd, but why wouldn't the A11 work too :S
I guess i jumped to conclusion too fast...
Now i have to make sure everything else is working as supposed to.
Regarding the 19v on the power button, the aforementioned Clevo is also Ivy bridge, has the same 19v on the power button like the M17x R4 and has no power on 3.3v and 5V until it's powered on.
I guess the difference between sandy and ivy bridge really is that great when it comes to off state and power button lolComment
so..... notebook is giving post to aliwnware logo ?
what problem has the clevo ? i have a clevo as ordinary pc... a p870km with z270 chipset and i5 9600k with modded bios . once it shut down after 1 sec... and was 1 defective ram.Comment
Yeah it posts and has already loaded to windows,
I've fully assembled it and looks like everything is recognized and working
Next i'm adding the external GPU to the laptop.
The Clevo shuts down after 1-2seconds.
I've swapped around the CPU, used all 3 different ram slots... BTW, weird, why would you have odd number of ram slots o.O
The laptop stays on if i remove ram from all slots, no beeps or anything.
All the rams are tested in other system so they are good, however when i add a ram to this one it wont power on.
Power on sequence is fully completed and then it turns off. The laptop is W350ET.Comment
sorry for late. today i wanted to look at my board and after flashing a13 bios and ec pc didnt power on annymore. wich version of ec and bios did u used ?
same a13 from rar for both bios and ec, or different ec and bios ?Comment
A11 didn't work for me and i haven't tried A12.Comment
by cind12Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
Resistance on 12V 4K ohms (Power present when on)
Resistance on 12V PEX 4K ohms... -
by zwectI have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
PCH doesn't seem to be shorted but i haven't done... -
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...09-06-2024, 06:42 AM
- Loading...
