Alienware M17x R4 no power, low resistance 5v/3.3v to GND
  • maxslo
    • Nov 2013
    • 64
    • Slovenia
    Hi, I have a M17x R4 board here that doesn't power on, the first thing i checked was power button and BIOS voltages.
    Power button was around 19v :/ and bios was at 0v, so not even close here.
    After poking around on the board with the help of schematics (In attachement)
    I've found out that the PQ27 and PQ28 (3.3v and 5v high side mosfets) werent outputting anything, both gates were at 0V.
    Further digging showed that both +5VALWP and +3VALWP had 13ohm resistance to ground only.
    I've removed PL10 and PL11, PC58 and PC63, desoldered all of the PJP3-PJP6 jumpers.
    Still showing 13 ohms when i check positive pad of PC58 or PC63 to GND.
    From what i understood from schematics the only way to have path to ground is via the PU4 (PSU Controller)... when i removed it it showed that there is open line on same points as was 13 ohms before. I've checked the VO1 and VO2 (PINs 24/7) out of circuit and they both have resistance in 100+ kOhms, putting the chip back in the board and the resistance drops to 2kOhms, plugging in ac and BAM, back to 13ohm...
    Here are the readings on PU4 when it's in circuit, shich all seem ok except the ones that are 0, but shouldn't be.
    EN is 3.13V
    REF, TONSEL, SKIPSEL are all 2V
    VREG3 is 3.3V
    VREG5 is 5V
    BOOT1 and BOOT2 are 4.55V both
    VIN is 19.5V
    everything else is 0V
    What am i missing here?
    Any help appreciated.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Alienware M17x R4 no power, low resistance 5v/3.3v to GND
    3.3, 5 and bios voltages comes only after power botton is pressed
    edit: u36 (near kbc) u have 3.3 volt on pin 8 ? is firmware of ec ok ?
    • maxslo
      • Nov 2013
      • 64
      • Slovenia
      Hi, i haven't thought about that, but power button should still have 3.3v and not 19v?
      The thing is that the PU4 is also heating up when the board is powered off.
      BIOS and EC were reflashed with a good working one (atleast others said that they worked for them).
      Look at that, U36 does have 3.3V on pin 8. How did i miss that :S
      I've added the original dumps and A11 that i've flashed to the attachments.
      Both chips were reprogrammed out of circuit.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Correct!
        You can also have a path to ground through PQ29 and PQ30 if they are faulty (shorted or leaky). Check continuity across them to check if are still good. Measure out of circuit if result in inconclusive.
        Depends which of the 2 BIOS chip you measured initially. EC BIOS (U36) is powered by +3VALW_EC (renamed from +3VLP) which is always present while main BIOS (U48) is powered by +3V_PCH which will come up after pressing power button (provided it meets required sequence)
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3593
          • slovakia
          that 19V on power butoon is really weird. find source of it.
          measure D26
          • maxslo
            • Nov 2013
            • 64
            • Slovenia
            Originally posted by Spider1211
            Correct!
            PQ29 and PQ30 were removed, the 15ohm is on the other side of PL10 / PL11 pads.
            Yeah i didn't realise that, i've measured the main BIOS chip not the EC one initially.
            measure D26
            The D26 is 1.8MOhms forwards and OL in reverse.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Did you replace PU4 or just soldered the old one back? If the latter, then try replacing PU4.
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                19volt on power botton is ok. after u press power botton ig toes to 3.3
                remove pjp3 or pjp4 , pjp5, pjp6. check if pu4 is ok or need replacement.
                pjp point all near pl10 and pl11. clean well with flux and desolder wick.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  OP already did that in post #1 (3rd paragraph). I have never seen 19V on power button, have you?
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    i was editing. nope never seen it. on schematic it get 3valways. i have that board that give 7 or 8 beep... no cpu and it has 19 volt on powerbotton that goes to 3 after u press power botton
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      Curious to know which board is that. Do you have a model number?
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        ls-6609p for m17x r4
                        • maxslo
                          • Nov 2013
                          • 64
                          • Slovenia
                          I've got a M17x R3 board that powers on but gives 7 beeps, i've scavanged the PU4 from there since based on the schematics it should be the same chip even though i can't get datasheet for it.
                          After replacing it, nothing changes, everything is exactly as before.
                          I also have a complete working M17x R3 that i can probe the power button on in off state to confirm what voltage is there.
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            when 19 volt on power botton could be a bad kb9300f... lets wait what volt he read on that working m17x and then we can make progression.
                            also rememer to remove pjp as posted
                            • maxslo
                              • Nov 2013
                              • 64
                              • Slovenia
                              Ok, i'll do that.
                              The PJP3-6 were all removed already, there was no change.
                              • maxslo
                                • Nov 2013
                                • 64
                                • Slovenia
                                On a good R3 board, the power button has 3.1V when in off state.
                                There is always 5V and 3.3V (not only after it's powered on) on the points where i don't have voltage on the R4 board.
                                Funny thing is that when it's in off state, it has 15ohm resistance to ground on that same points, so i guess this is not the problem??
                                I'll put the board back together and double check my measurements on the faulty r4 board.
                                Edit: on working laptop the resistance to ground measured on PL11 was actually 0ohm when the laptop was turned on o.O how can it be dead shorted to ground.
                                • maxslo
                                  • Nov 2013
                                  • 64
                                  • Slovenia
                                  If it comes down to KB930QF, since it's the same chip on the R3, can i just swap it around, or does it have to be programmed?
                                  • dellxps15
                                    • Feb 2014
                                    • 1588
                                    • italy
                                    keep in mind that this r4 i have here has 19 volt on pwbtn too , but it beep as no cpu even if cpu get hot.
                                    without pressing power botton,
                                    on jbtn pin 1 that should be 5vs is 0 volt
                                    pin 2 is 19 volt.
                                    d26 has 19 volt on pin 2 and 3, and has 3.3 on pin 1 (dont look at scheamtic for pinout)
                                    L43 has 3.3 volt
                                    r262 has 3.36 volt both side
                                    pu3 pin 1 is 5 volt
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      page 53, pr32 and pr33 are the cause of 19volt on power botton.
                                      edit their valure are ok..... 100k and 22k...
                                      pq7 has 19 volt
                                      im thinking that on m17x r4 19volt is normal...
                                      edit2 : cant remember well 100% as long time passed, but i had a m17x r4 fully working and i think i compared that 19v to it...and the fully working one has that volts too, but not sure 100%
                                      • maxslo
                                        • Nov 2013
                                        • 64
                                        • Slovenia
                                        pin 2 is 19 volt.
                                        L43 has 3.3 volt
                                        pu3 pin 1 is 5 volt
                                        Everything is as you have, except 19V voltage is a bit lower at 18-18.5V
                                          Alienware M17x Gaming Laptop Schematic
                                          Alienware M17x Gaming Laptop Schematic...
                                          11-01-2024, 04:56 AM
                                        • cind12
                                          GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                          by cind12
                                          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                          Resistance on 12V 4K ohms (Power present when on)
                                          Resistance on 12V PEX 4K ohms...
                                          12-08-2023, 09:09 AM
                                        • zwect
                                          Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                                          by zwect
                                          I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                                          While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                                          PCH doesn't seem to be shorted but i haven't done...
                                          12-29-2024, 06:57 PM
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                          Alienware 13 R3 Notebook Specification for Upgrade or Repair
                                          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                                          09-06-2024, 06:42 AM
