Help with bios programmer (EZP2019+)
  • jamaicaboy
    • May 2023
    • jamaica
    Re: Help with bios programmer (EZP2019+)
    Hello I'm using the EZP2023, when I try to detect some chips the programmer shows me PLEASE MANUALLY SELECT THE CORRESPONDING TYPE BURN,. What does this mean?, and what should be the first thing to do whatever I come across this that message?. THANK YOU .
    • ogre4273
      • Mar 2022
      • 57
      • N/A
      I dump two files of the same bios chip with different speed (3 mhz and 12 mhz) now why are there differences when i try to compare them using hxd? Does it matter or it will not affect the dump
      • linh0983
        • Jun 2023
        • VN
        Originally posted by jarikatunari
        I have tried but without success
        I want to read W25Q128FVPQ with EZP2019+ but canr read.
        what can I use to read/write W25Q128FVPQ
        This box can support all kinds of chips you can refer to .
        http://www.xgecu.com/en/
        Last edited by SMDFlea; 06-21-2023, 09:02 AM. Reason: Posted external images to badcaps
        • Bravetech
          • Jul 2023
          • 5
          • Nigeria
          Hello friends please I have problem with the new EZP 2023 programmer, after insering the chip into SOIC, when I read the bios is says chip empty. Anyone with the solutiaon
          • samtron786
            • Aug 2016
            • 157
            • germany
            Originally posted by peteruitnl
            NOT CONNECT
            That's a driver problem.
            Drivers are included with the software.
            Go to Device Manager and look under USB
            Install the driver for the EZP2019 programmer.
            Problem solved.
            Don't forget to deactivate the driver signature :-)
            • aa10aa10
              • Sep 2024
              • 6
              • Lithuania
              #26
              Hi! Long story short - I wanted to remove supervisor password from BIOS (MX25L12873F chip). I have read BIOS using AFUWINGUI64 (8MB), edited and pressed write - AFU started erasing the chip and then it showed error. I didn't manage to write BIOS using AFU - not original, nor edited. Then I have rebooted - no post, only power light is on. I have disassembled notebook, connected EZP2010 programmer and read the chip (16MB) using EZP2011 v3.0 (chip was detected as MX25L12805D). I have replaced corrupted partly erased BIOS part from 16MB file to previously read 8MB BIOS. Still no post. EZP erases this chip, verification of erased chip passes, then EZP writes this chip and verification of written chip passes. I have afterwards read the chip and compared both files using VBinDiff - files are the same.
              I have also tried another BIOS dumps found here from similar model - still no luck.
              So the question is - I need another programmer for this chip? Could there be any problems with EZP taking into account that verification passes?
              • yuyuyak
                • Mar 2025
                • 11
                • US
                #27
                I have successfully used the EZP2019+ to read and program my MX25L12873F. And successfully added it to the definitions table. Please see this post for details.
                • MAGRAW TV
                  Emmanuelly
                  • Mar 2024
                  • Nigeria
                  #28
                  I have an EZP 2023+, bios programmer which was able to detect the BIOS mentioned below.
                  But when I tried reading the file of the bios chips - 25q32f - from HP 455 g1, I couldn't get the bios bin. I then click on the device bar at the top of the bios software, I tried adding the specific BIOS, but all to no avail.
                  What else can I do to get the original bios dumb from the bios chips before formatting it. Is there any other software?
                  • yuyuyak
                    • Mar 2025
                    • 11
                    • US
                    #29
                    Are you trying to read it using a clip? They are extremely unreliable.
                    • STKR123
                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                      by STKR123
                      Greetings badcaps community,
                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                      I learned that desoldering...
                      10-29-2024, 06:03 AM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
                    • zlr8r
                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                      by zlr8r
                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                      cheers
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                      Attached;
                      1. My saved bios using a programmer
                      2. Dells Bios updater .exe (v1.16)
                      3. Dells Bios recovery file
                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                      5. Image of ME...
                      12-18-2023, 03:08 PM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • what_1282105
                      Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                      by what_1282105
                      Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                      02-14-2025, 07:27 PM
