asus g752vy power button partially not working
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, this laptop was broken..i tested it..find short...replaced ite chip and 3/5 voltage regulator and everything is working fine...i tested it and all ok...but...later when i tried to put it together every time i connected touchpad button the red light on the power button was missing (the laptop is working, touchpad is working) just missing that red power button light). And when i unplug touchpad it was there... So whats going on...?
    I measure power led on both side and it is 5,06 V on one side...but when touchpad is connected there is a difference on other side "PWR_LED_CON#_1" ...when touchpad is not connected it is 3,26 V but when connected it is 3,7 V. Ok, so that it is why i dont see red power button light...
    So i inspected touchpad ribbon cable and connector and everything seems fine...i even used a second touchpad button of the same model i have and same...no red light when connected. Oh and i should mention that touchpad button is working fine when connected...only no power light on main button.
    So i use schematic (attached similar model but should be the same) and i found following:
    1. PWR_LED_CON#_1 without touchpad 3,2, with touchpad 3,7
    2. PWR_LED_CON# is on pin 9 of touchpad...should be 0 v but it is 2,8 V. Also it is shorted with 0 ohm resistor to a "PWR_LED_R#" (gate on mosfet see attached picture below)
    3. Without touchpad connected the readings on n mosfet are pin 2,3 0 v, pin 1,4 GND, pin 5,6 are 3,3 V (i believe this is ok, as it shoud be always)
    4. When touchpad connected readings are on pin 5,6 0v, and on pin 2 2,8v, pin 3 3,7 v
    So far i tried check for short (didnt find),replaced mosfet but the same....
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Re: asus g752vy power button partially not working
    i measure every pin from touchpad button on working and this laptop and only difference is in pin 9 PWR_LED_CON# / PWR_LED_R#...on working laptop is 0 v but on this it is 2,7 V. I am not able to figure how PWR_LED_R# is generated?
    Also i removed resistor R5623 but still on pin 1 - PWR_LED_CON#_1 i have 3,7 v ?!
    Maybe trying to flash bios? i dont know...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3560
      • slovakia
      that # means it is active when low so 0V.
      • myth77
        • Feb 2017
        • 380
        • Croatia
        Hi, thx for helping...
        What do you mean "low so 0v"? Can you explain? Do you mean that every signal that has # should be low when power is ok?
        • myth77
          • Feb 2017
          • 380
          • Croatia
          I removed 0 ohm resistor R5620 and now i have a light on main power button...but problem is still present on the other side signal PWR_LED_CON# which is generated from touchpad button? according to the scheme...but i dont understand how?
          • reessi
            Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
            by reessi
            With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
            No corrosion any where!
            Tried a replacement power button off ebay and the same.
            Very occasionally it will work with the power button connected!
            Same results with or without the battery.
            Can it be a fault with the Audio board or the mainboard?
            The touch Id assembly connects through the Audio board first then to the Mainboard.
            Flex...
            06-26-2024, 03:31 PM
          • themosttogain
            HP Envy 13-BA1565na with intermittent power button
            by themosttogain
            Hope someone can give me some suggestions on this because i'm at my wits end with it...
            I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
            Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
            07-12-2024, 03:03 AM
          • techpointhull
            HP OMEN 16-WF0032TX NO Power unless the button is held and AC adapter connected
            by techpointhull
            Hi Guys,
            Got a weird one here. I have a HP OMEN 16-WF0032TX that's in my shop for no power. If I disconnect the battery, and the AC adapter and hold the power-on button on the keyboard, when I connect the adapter the laptop powers on. If I shutdown and close the lid, once I re-open the lid and press the power button, no power. If I shutdown and keep the lid open, when I press the button the laptop powers on.
            I have checked around the display connector if I can see anything that doesn't look right, its like an issue with the lid sensor. Has anyone seen this before?...
            12-10-2023, 12:32 PM
          • TimeRabbit07
            Asus FX517ZC charges but power button does nothing
            by TimeRabbit07
            Hi all!
            I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
            Here are its various numbers and identifiers:
            Model short: FX517Z
            Model long: FX517ZC-HN114W
            SN: NANRCX01S57842E
            CN: 3SDB 12M
            MFD: 2022-10
            Motherboard model: DA0NJLMBAE0 REV E
            Symptoms:
            The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
            History so far:
            The...
            09-04-2024, 05:48 PM
          • BillyJ
            Troubleshooting dead Apple MacBook Pro A1398 (820-00426-A)
            by BillyJ
            Hi all, first post here looking for some troubleshooting assistance with my A1398 mid-2015 MBP.
            820-00426-A
            History:
            Many drops but nothing before failure
            Many failed kernel crashes but nothing before failure
            No water damage
            No indication of imminent failure
            Magsafe (genuine apple 85W version) goes green then orange
            The computer was asleep with the screen closed
            I opened the screen but the screen stayed black and fans not spinning like it was asleep
            the click pad was working but computer unresponsive to power...
            11-01-2021, 06:21 AM
