Richtek rt8249c equivalent !
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Or who know mobo ref - mine is Asus X541 NA
  • peste
    • 13573
    • ROMANIA
    Re: Richtek rt8249c equivalent !
    Originally posted by lapfix
    richtek rt8249c equivalent !
    Or who know mobo ref - mine is asus x541 na
    rt8249cgqw rt8249c (2n=2j 2n=eg 2n=de 2n=...) qfn-20
      • 21850
      ********** wrong info
      • dennison flores
        • Apr 2021
        • 22
        • Philippines
        Originally posted by SMDFlea
        TPS51225C is equivalent .
        THANK you very much sir SMDFLEA
        • SERGEY1962
          • Jun 2016
          • 14
          • Holland
          Not an equivalent - RT8249C has pin 19 as SKIPSEL (PWM Operating Mode Selection) and TPS51225C has pin 19 as VCLK (Charge Pump Output Clock). TPS51225C is only an equivalent to RT8249A/B and RT6585A/B. It is however possible to use TPS51225C in place of RT8249C but it is required to cut off pad 19 underneath the IC to separate the circuit from pin 19.
            • 21850
            Thanks for the correction
            • sahamipoor
              • Nov 2016
              • 42
              • india
              it's equivalent to RT6575b but you need remove 19 pin of pad.
              RT6575=RT8249C =2Q (and 2N= by remove pin 19 on pad).
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • f-bone
                Asus X512D(A) pulsing 3.3VA_EC.
                by f-bone
                hi guys,
                this one only has a boardview and I can see 3.3VA_EC pulsing (as is PU8701 3VAO+) along with the power led. I injected 3.3V on that line but nothing warms up (0.01A draw) except the EC slightly which can be normal.
                I tried another bios incase it is related somehow and a 51225C (dont have rt8249C in stock, https://www.badcaps.net/forum/troubl...35#post1637735) with pin19 isolated (and also connected) - same result.
                01-11-2024, 09:10 AM
              • Cerberuska
                Mobo MSI B550-A PRO password popup
                by Cerberuska
                Hello guys,
                I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                BIOS I updated to last one.
                any suggestions?
                And same thing for two different 5600G, and yes, MoBo supposed to support it.
                Thank you...
                11-10-2024, 01:23 PM
              • mrsith
                Dell G3 17 3779 - no display after mobo replacement
                by mrsith
                Hi guys,
                I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                04-30-2023, 05:11 AM
              • Ibod
                Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                by Ibod
                HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                Not sure where to go from here ?
                Is the PSU at fault or is the mobo causing the problem
                Look forward to any help :-)
                If I plug the 24...
                02-08-2023, 11:00 AM
