Macbook pro 2012 820-3115-B Greenlight no Power on
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook pro 2012 820-3115-B Greenlight no Power on
    q7220 volt ? all pin
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      here you go my friend..
      Pin 1 P3V3S5_DRVH = 0.860v
      Pin 2 PPBUS_S5_HS_Other_ISNS= 12.58v
      Pin 3 GND
      Pin 4 GND
      Pin 5 GND
      Pin 6 P3V3S5_DRVL = 0v
      Pin 7 P3V3S5_LL = 0v
      • piernov
        • Jan 2016
        • 4439
        • France
        For sure something went wrong between the beginning and now…
        You have to fix PP5V_S5 first. Either shorted to ground or bad U7200.
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Thanks a lot for that information...I will change U7200 for a new 1...and see how it goes ..and report back for sure..
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
