inspiron 15 dead with blinknig power light
  • mo000
    • Nov 2017
    • 285
    • algeria
    hi
    dell inspiron 15 10316-1 dv15 hr 48.4ip16.011
    power light blinking
    nothing else
    3.3 and 5v ok .
    where is the problem ? .
    please help .
  • mo000
    • Nov 2017
    • 285
    • algeria
    Re: inspiron 15 dead with blinknig power light
    help .
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      did u use original charger with enough power?
      • mo000
        • Nov 2017
        • 285
        • algeria
        yes , i use 2 charger .
          Laptop computer that went completely dead no boot no power light no hard drive light
          by sam_sam_sam
          See pictures for type of laptop computer
          I checked switching power supply brick 19.2 volts multi meter only
          No booting without switching power supply connected
          Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
          What the heck is going on here...
          04-04-2025, 04:58 AM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
        • ipatch
          troubleshooting microsoft surface pro 4 no power no led charge light
          by ipatch
          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
          10-05-2023, 11:59 AM
        • russpall
          LG 39ln540v - red light flashes twice, no power to LED driver?
          by russpall
          Hi there,
          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
          08-27-2024, 01:07 PM
