inspiron 15 dead with blinknig power light
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi
    dell inspiron 15 10316-1 dv15 hr 48.4ip16.011
    power light blinking
    nothing else
    3.3 and 5v ok .
    where is the problem ? .
    please help .
  • mo000
    • Nov 2017
    • 276
    • algeria
    Re: inspiron 15 dead with blinknig power light
    help .
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3592
      • slovakia
      did u use original charger with enough power?
      • mo000
        • Nov 2017
        • 276
        • algeria
        yes , i use 2 charger .
          Laptop computer that went completely dead no boot no power light no hard drive light
          See pictures for type of laptop computer
          I checked switching power supply brick 19.2 volts multi meter only
          No booting without switching power supply connected
          Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
          What the heck is going on here...
          04-04-2025, 04:58 AM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ipatch
          troubleshooting microsoft surface pro 4 no power no led charge light
          by ipatch
          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
          10-05-2023, 11:59 AM
        • russpall
          LG 39ln540v - red light flashes twice, no power to LED driver?
          by russpall
          Hi there,
          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
          08-27-2024, 01:07 PM
        • Andreasbest
          Dell Latitude 7410 dead and amber light as long power button is pressed.
          by Andreasbest
          Hello.
          I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
          Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
          Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
          Fact #3 i tried hard reset with cmos/main battery disconnected and power...
          12-21-2024, 02:02 PM
