HP Board La-C701P-Work only with external Monitor
  • vabea
    • Dec 2019
    • 41
    • Portugal
    Hello, i have this Hp board (LA-C701P), it work but no image (only with external monitor) when i power on the lcd stay a more black but no image, i have change the lcd without results.
    Any idea?
    regards
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Re: HP Board La-C701P-Work only with external Monitor
    du u have discrete GPU?
    • vabea
      • Dec 2019
      • 41
      • Portugal
      No, only the cpu graphics card...
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3582
        • slovakia
        did u have all needed voltage on LVDS? did u try to change LVDS cable?
        • vabea
          • Dec 2019
          • 41
          • Portugal
          Pin 15 and 16(+LCDVDD) in board connector is 0v, i dont have a 2º cable to test but the pin 1 and 2 dont have continuity between the connectors and according the Schematics i have pin 1 and 2 are (LVDS_TXP0, LVDS_TXN0).
          maybe a cable problem?
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Upload the Schematic to help
            • vabea
              • Dec 2019
              • 41
              • Portugal
              I have download this Schematic:
              https://www.badcaps.net/forum/attach...2&d=1562740525
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Check UG1 pin 1 3 4 5 voltage & check INVPWR_B + 19V on the LVDS 28/29
                • vabea
                  • Dec 2019
                  • 41
                  • Portugal
                  28 and 29 , 19v
                  4,5 - 3,3v
                  1,2,3 - 0v
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    Back trace R172 should be near the IC what voltage other side ? Short pin 5 & 1 just to check voltage is crossing +3V
                    • vabea
                      • Dec 2019
                      • 41
                      • Portugal
                      Short 5 and 1 nothing happens, voltage in R172 is 0v
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        You have to keep holding from a tweezer or put a jumper that voltage must cross over , check voltage LVDS pin 37 38 27 28 15 16 screen must be connected
                        • Dumah Brazorf
                          • Jun 2013
                          • 179
                          • Italy
                          How's started? Have you disconnected the panel with the battery connected?
                          • vabea
                            • Dec 2019
                            • 41
                            • Portugal
                            When i short (1,5) i lost de 3,3v in pin 5 (stay o volt) only 3,3 v in pin 4, with the short 37,38 - 0 v; 27,28-19v; 15,16-0v
                            Without short same voltage in LVDS
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              remove UG1 & test all pins again for voltage after test Ohms in pin 1 you have 2 caps in this line CG2 CG3 test one of the are fault or not their is another prob DATA & CLK is missing on pin 37 38 LVDS was the screen connected when you check voltage ?
                              • vabea
                                • Dec 2019
                                • 41
                                • Portugal
                                I dont see the capacitores, do you see them in the image i attached? yes when i test the pins 37,38 the screen was connected...
                                • vabea
                                  • Dec 2019
                                  • 41
                                  • Portugal
                                  i remove the UG1, and only in pin 4 i have voltage (3,3v)
                                  • vabea
                                    • Dec 2019
                                    • 41
                                    • Portugal
                                    Hello i have correct the issue, thanks for the help techtiger, like you say when i remove the UG1 and short pin 1-5, i have have all the voltages in the lvds pins, but still not working, so o chage the cable, and now are working...
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • maralexbar
                                      How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                      by maralexbar
                                      I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                      It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                      If anyone knows how to force the external monitor as primary for Notebooks of those models
                                      11-02-2024, 09:18 AM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • penangit
                                      Hp v193 monitor power supply board
                                      by penangit
                                      Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                      I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                      I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                      Steps taken so far:
                                      Checked all...
                                      02-21-2023, 04:00 AM
