Cleaning cooling laptop fans
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I received acer predator helios 300 with overheating issue. So when i disassemble it i could see a lot of dust everywhere. To clean it proper i had to open the fans because they didnt even spin because of the dust. So i clean everything and put a good quality thermal paste...but i have the problem. One of the fans is not spining..it is trying because i can see a little move but its seems stucked. So i disassmble it again and try to clean it again with isopropil alcohol...and it worked... but for only a day. Tomorrow again not spining. Again i used isopropil alcohol to clean the vent niddle and magnets and again it worked for a day.
    Do you have any suggestions? Somewhere i read to use some sort of greas in place where fan niddle is sitting on the magnetic/housing part but i am not sure..What is your expirience on this subject?
    Thank you!
    • 21209
    Re: Cleaning cooling laptop fans
    I use sewing machine oil on fan spindles ,isopropyl is no good as it evaporates. Don`t put any oil on the magnet,just clean it with a cloth and isopropyl.
    • krawat274
      • Jun 2020
      • 53
      • Poland
      Hello. Maybe you can unmount fan and check it by laboratory power supply if it work correctly?
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        Shot bearings. You may try to use lab supply to boost voltage, and maybe this will help loosen up things.
        Problem with these fans, there is no direct approach to clean them, they are sealed and unserviceable. And fan assembly is not removable.
        Bearings creates too much friction so stock voltage would not spin them up.
          • 21209
          The fan rotor lifts off. https://www.youtube.com/watch?v=eTuNyfflFSo 5 min 20 sec
          • myth77
            • Feb 2017
            • 380
            • Croatia
            yes, i am talking about fan rotor...I lifted it off, cleaned, also cleaned magnetic part...and it is working..for a day..then stuck again...its trying to move..i can see little movement in a part of the second...then i clean it again...working..tomorrow not working. I guess i will have to buy sewing machine oil and give it a try...
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              What type of oil you use for lubrication?
              • myth77
                • Feb 2017
                • 380
                • Croatia
                i didnt use it before...cleaning was always enough...but this time it isnt. So i will try what SMDFlea suggested.
                • televizora
                  ghettomodmaster
                  • Nov 2016
                  • 957
                  Lift the rotor and oil with thin oil. Silicone oil..Or just hydraulic oil. Put oil where the rotor goes into the stator.
                  Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                  1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                  • mosfetratus
                    Sure Not
                    • Feb 2019
                    • 174
                    • Resistron
                    Cleaning is not enough, because bare metal creates oxides increases friction, bare metal to metal contact is also big friction. Oil will reduce friction to a minimum and will protect from oxidation. Sewing machine oil is OK, since it can handle high RPM and is good in dusty environments.
                    a single drop of oil will be more than enough.
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      why not buy a new processor fan it will solve your problem
                      • howardc64
                        Macbook Dust-Gate Preventive Cleaning
                        by howardc64
                        Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                        Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                        https://www.ifixit.com/Guide/MacBook...leaning/177920
                        10-09-2024, 10:10 AM
                      • emil_t
                        RTX3090 working fine but fans not spinning
                        by emil_t
                        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                        04-12-2024, 06:54 AM
                      • RetroComputingGrotto
                        IBM LTO 7 Tape Drive - Dust Sensors??
                        by RetroComputingGrotto
                        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                        09-19-2024, 01:54 AM
                      • johnnylotto
                        System76 partial power-on, VDD1.05 out fail
                        by johnnylotto
                        Laptop:
                        Hello, I have a System76 Gazelle laptop (model gaze14) which now only partially powers on and does not boot properly.
                        History:
                        This laptop has served me well for a few years. It's always been a bit noisy with the fans and recently became much more so on both fans, where just opening a vim/notepad session would cause the fans to spin up loudly and make a grating sound, like the ball bearing were mechanically wearing out. So after blowing the dust out of the fans out didn't help, I ordered replacement fans and heat sink component from System76 which were sold...
                        09-18-2022, 01:06 AM
                      • ronaldopdias
                        Alienware M17 R3 - LA-J521P - CPU Fan not working.
                        by ronaldopdias
                        Hi.
                        I got this laptop with an overheating issue.
                        After opening, I found both fans clogged with dust and nicotine.
                        GPU Fan started to work after the disgusting cleaning, but the CPU Fan is dead. I ordered a new fan and replaced it, and it's still not working.
                        Further diagnostics show that the PWM signal from the EC Chip is OL.
                        Fan connector:
                        1 = +12V_FAN
                        2 = Open Line 0V This line comes from the EC chip. CPU_FAN_PWM
                        3 = +5VS - CPU_FAN_FB
                        4 = GND
                        I think because the fan was stuck for so long it damaged the line from the EC. The line...
                        03-27-2025, 04:12 AM
