hp 435
  • gualancho
    • Jul 2020
    • mexico
    hp 435
    good morning i have ua hp 435 that the power connector led turns on but it does not turn on
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: hp 435
    check bios
    • lapfix
      • Mar 2020
      • 2744
      • my workshop
      Re: hp 435
      You give us a very little informations , so take more measurements on all coils, make a visual inspection to see abnormal things, how many amps your power supply take , see if there's any short ..etc
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        Re: hp 435
        please specify the symptoms and all the things you've done so far with this laptop
        • Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
          by Stephen
          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
          03-15-2024, 09:37 AM
        • www
          LG L192WS-BN backlight turns off after 1 second
          by www
          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
          03-24-2024, 05:26 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • andrhouseolly
          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
          by andrhouseolly
          Hi.
          I kindly ask you to help me solve the problem.
          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
          The board turns on, there is no image.
          Read more. When the power supply is connected, the front panel indicators light up briefly.
          When you press the power button, the button indicator lights up. The board works
          there is no image, there is no matrix initialization, there is no image on HDMI.
          When turned on, the fans do not spin, but when they warm up they start spinning.
          When you turn off the button, the fans spin up to full speed for a short...
          05-11-2024, 03:14 PM
        • mostachio
          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
          by mostachio
          Hi Badcaps,
          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
          TV Details:
          Model # - TH-65DX700Z
          Symptoms:
          The television turns on and displays a picture then makes a clicking sound and turns off.
          I haven't opened it up yet but...
          09-04-2024, 02:32 AM
