Clevo n870hc / No boot
    Hi Guys,
    I looking for some advice.
    I have a Clevo n870hc that's has stopped working. Plugging the power adaptor in and displays a amber light on front. (No Battery installed)
    If power button is pressed that the led turns green for a few seconds and go back to amber.
    With battery attached the changing circuit seems to be fine and laptop was displays amber and when battery is
    changed it goes green as it should so i'm guessing the ITE is working.
    On the odd occasion when pressing the power button, the power button led stays on and both the CPU and GPU fans kick in but after a few seconds they
    shuts down and wont restart. On that occasion the screen stays blank and displays nothing, not even a back light.
    Where would the best place for me to start?
    Re: Clevo n870hc / No boot
    Doing some basic testing:
    AC Port = 19.30v
    Bios u43 = Ground + pin 8 = 2.84v (Pin 1 + 8 = 2.84v)
    Will update when i get more
      did you do all the basics. substitute with known working memory module.. check the rtc cmos battery, check all the ALW voltages the 3.3ALW and 5vALW.. try to reflash bios with known working bios dump. be sure to save your original bios for backup. look for burnt parts or overheating parts... gud luck
      Never stop LEARNING because life never stops TEACHING!
        Thanks Duranitron
        I have started doing a cap test and found shorts in:
        Page 66 - Gpu
        c587, c616, c618, c619, c621
        Page 55 - Processor 5/6
        c594, c595
        Page 56 - Processor 6/6
        c596, c579
        Before i start changing the caps, i cant seem to find what may have caused the issue. Possable GPU/CPU Temp?
          It also seem to be around the bottom of the board as well, in the cpu and gpu area.
          Unless i am doing something wrong?
            do diode mode test and test it again.. remember the processor or gpu only uses 1.2v or less a low resistance like 10 to 3 ohms are good or maybe a cap is fried.
              have you check the processor fan for gummed or clogged dirt in side.. that maybe the cause.. an over heating processor or a toasted gpu...do you own this laptop if so.. before a gpu die it displays symptoms like sudden hung.. blue screen of death or screen freezes but the mouse pointer moves.. that kind of thing.. try to look for shorted cap and hoping to find shorted one or if not.. the gpu is toasted..
                I removed cap c578, tested on bench and works fine removed
                  Checked and could not see anything in the fan. Its my unit and did not see anything.
                    So I'm guessing I have a short on the gpu and cpu side as I get a connection to ground even on the CPU points on top.
                    What's the best way to test faulty caps without removing one side? Or is there no way without proper equipment?
                    I am just working my may thought the diagrams if anyone can point me to something else that may be causing it?
                    Would a dead gpu/CPU cause everything to ground?
                      Measure exact resistance to ground. 6 ohms to ground on CPU VCore for Kaby Lake is perfectly fine. GPU VCore may be similar or even lower.
                        Hi piernov,
                        Is that with no power attached?
                          I have been working on finding 19v and 3.3v and they seem to be fine but i cant find the 5v rail.
                          Can anyone tell me if on page 84 the type-c, 5v should that be always live with ac connected?
                            Check page 90 5V, 5VS, 3.3V, 3.3VS, 3.3VA if all voltage are available then follow the power sequence page 107 & feedback what’s missing
                              Thanks tachtiger
                              v3.3
                              u31
                              pin 1,2,6,7 - vdd3 - v3.3
                              pin 8,9 - 3.3vs - v0.00
                              pin 13,14 - 3.3v - v0.00
                              v5
                              u30
                              pin 1,2,6,7 vdd5 - v0.00
                              pin 8,9 - 5vs - v0.00
                              pin 13,14 - 5v - v0.00
                              u26 - VA
                              1 - 19.28v
                              So it does look like i have 5v is rail down. I have been looking at the type-c/usb 3.0 area as i can see a bit of what looks like liquid damage as U14 looks a bit crusty.
                                Thanks tachtiger
                                v3.3
                                u31
                                v5
                                u30
                                u26 - VA
                                1 - 19.28v
                                DD_ON# SUSB# missing trace it back U31 pin 8.9 5VS not 3VS
                                  Thanks tachtiger for all your help
                                  Getting there slowly
                                  Nothing from pin 4 on PQ42. just tracing DD_ON# & SUSB# now.
                                    find out PJ501 jumper if its' soldered remove it & see if 5V is there or not if not check the resistance to gnd of both pads
                                      Removed and got about 0.65v and then it started to slowly drop on pins 1,2,6,7 - u31
                                        Pad on side of U31 - no resistance
                                        Pad other side - 1.191
