Dell XPS 9560 AC Adapter Unknown
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on a Dell XPS 9560 that had a damaged DC jack. Customer kept using it despite broken barrel on DC jack. Now after checking it with a known good charger and new jack (tested and functioning on another XPS) it still reports AC adapter unknown and will not charge the battery. Battery health is good. So question is, what on motherboard is responsible for the failure to identify AC adapter?
    Thanks. FYI, there was similar thread but the OP reported as fixed with no details
    Motherboard DPN: YH90J
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Dell XPS 9560 AC Adapter Unknown
    The AC adapter has three wires. the third one is called ID and is for identification. measure voltage on all pins of the DC jack.
    • petehall347
      • Jan 2015
      • 4423
      • United Kingdom
      it might be possible to modify the charger .
      • Weelcup
        TopTech
        • Oct 2017
        • 300
        Do you have a USBC charger 130w. If so try it to charge the battery. Use the usbc port of course.
        I think your issue will be related to the charging IC. But i am not 100% sure for now.
          Is this the DC jack you have?
          https://www.amazon.com/HengXC-Jack-C.../dp/B07BH5FCKV
          The white wire is the DATA pin for the AC adapter to talk to the mother board to identify itself.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Which kbc it uses?? You need to find AD_ID pin on kbc and check whether you have stable and correct voltage there. Trace it back for a resistor valued 33.3Ohms which is culprit in many cases for adapter identification failure.
            • mgrharry
              • Sep 2016
              • 211
              • usa
              @caspian - when plugged into motherboard with battery attached, the jack measures 19.6V on 3 red wires, 3.3V on white wire
              @wheelcup - I have a 90W USB C charger. It's not enough to power the system but I'll see if it will trickle charge.
              @budm - yes that's the jack I have. And as I mentioned in OP I was able to test the new jack with another XPS motherboard and can confirm both the jack and charger work fine with that alternate motherboard.
              @mcplslg123 by KBC are you refering to keyboard controller? power button on this model is on the motherboard itself, not on KB if that answers your question.
              Thanks everyone.
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                only red and white wire?
                there is supposed to be a third color wire on the AC adapter too.
                • mgrharry
                  • Sep 2016
                  • 211
                  • usa
                  @caspian - black ground wires 0v
                  Here are some closeups of the area around where the jack connects, top side and bottom.
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    then, the AC adapter seems fine and the fault is on the mainboard.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      @mgrharry, You misunderstood my point. Yes kbc=keyboard controller. I asked you to check AD_ID which tells us whether adapter is recognised by kbc or not-it has nothing to do with power button. In between your dc jack to kbc AD_ID pin there are other components and a resistor valued at 33.3Ohms. You need to check it.
                      • shibu
                        • Apr 2016
                        • 28
                        • uae
                        hi the ad_id circuit is almost same every dell motherboard so you can trace any dell diagram to find out just search in diagram adp_id/psid/pjpdc/dc jack!!!!
                        • mgrharry
                          • Sep 2016
                          • 211
                          • usa
                          Here's a snap of the KBC diagram for a similar model. I'm not great at reading schematics though and there don't seem to be board views for these models. Anyone give me a push in the right direction here?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Right direction was showed to you but perhaps you didnt do your job. Was you able to track ps id signal and 33.3 ohms resistor??
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              agree with "mcplslg123""
                              just follow the ps_id line if you want to fix this issue
                              find out 33.3 ohms resistor and protection fet
                              • mgrharry
                                • Sep 2016
                                • 211
                                • usa
                                Schematic for 9550 can be found here on badcaps.
                                I replaced PQ100 and the two resistors indicated with red arrows with ones from a donor board of the same model that had liquid damage in a different area.
                                It now recognizes charger wattage! Yaay.... but... only sometimes. Boo. Thinking there's another fet that's bad.
                                Suggestions?
                                • mgrharry
                                  • Sep 2016
                                  • 211
                                  • usa
                                  After pluggin / unplugging the charger a few times it is back to the original behavior and no longer recognizes the wattage. Maybe my PQ100 donor was bad.
                                  • mgrharry
                                    • Sep 2016
                                    • 211
                                    • usa
                                    Fixed. Thanks to @mcplslg123 for serving it up on a platter. I was misreading the schematic and had replaced two other resistors but once I located and replaced the 33ohm resistor off PQ100, problem solved.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Nice job bro in the end.
                                      • jagiro84x
                                        • Mar 2022
                                        • 19
                                        • Holland
                                        hello m8 i am facing same issiue, could you please please provide picture where the resistor that needs to be replaced is located on motherboard? i have the xps 15 9530
                                        • mcplslg123
                                          Dell 7506 2-in-1 laptop-no ac adapter issue
                                          by mcplslg123
                                          MODEL:ELL 7506 2-IN-1
                                          M/B: HELLCAT 14 MS TGL 8L (19860-1)
                                          PROBLEM: NO AC ADAPTER
                                          The unit works fine with adapter but gives this message. The adapter is genuine dell 65W(tested ok). PS_ID is working correctly and reaches SIO.R4305 is correct at 33.3 ohms.
                                          PU4301 gate is correct at 3.3V as well as PU4415 gate voltage at 1.8V is correct. 19V reaches PR4401(CLR).
                                          Charging IC is ISL9538C
                                          01 Resistance between CSIP/CSIN is about 2.2 ohms(PR4422/4423 is of correct value)
                                          02.Resistance between CSOP/CSON is also correct at 2.4 ohms (PR4424-25 is...
                                          11-18-2024, 11:34 PM
                                          DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                                          09-06-2024, 07:11 AM
