MacBookPro A1502 820-3536 kernel panic.
  • Francisco.s
    • 686
    • Spain
    Hi, this MacBook boots with its internal ssd a bit slow.
    With a windows based boot disk, it boots witout problems and with normal speed.
    I've tried to boot from asd 3s162, and it boots but shows a message of kernel panic "failure missing me".
    With asd162 "EFI" didn't pass "Management engine presence test".
    I have tested two different clean ME bios and the problem's still the same.
    Any hint to solve the problem?
    Thanks in advance.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: MacBookPro A1502 820-3536 kernel panic.
    If you're 100% sure ME region has been cleaned properly, check/replace Q1920.
    • Francisco.s
      • 686
      • Spain
      Thanks piernov for your quick answer.
      I have no other dual mosfet for replace Q1920, but al voltages seems to be good in its pins.
      pin 3= 1.5 volts
      pin 2= 3.4 volts
      pin 4, 5, 6= 0,01
      SPI_DESCRIPTOR_OVERRIDE has no voltage. (I think it has to be at high level in order to write the ME region)
      Bios dumps are downloaded from other internet forums and marked as "cleaned".
      I will try to clean the original bios and post if it solve the problem.
      Have you seen this messages before?
      • Francisco.s
        • 686
        • Spain
        As I was not 100% sure about ME region, I made my own dump cleaning the original dump, but something went wrong and it didn't boot.
        So I decided to test other bios from this forum, and by mistake downloaded a dump from this link: https://www.badcaps.net/forum/showpo...4&postcount=14
        At first didn't notice that this bios is for a 820-3476-A, not the 820-3536.
        The weird thing is that it chimes with no delay, and boot asd without kernel panic.
        Asd362 now boots and makes all test,but sows a few errors:
        Local machine info: Mac OS X version = 10.9(13A3017) IP Address:127.0.0.1 ASD version:3S162
        ASD Log activity from [06/22/20 16:22:41] to [06/22/20 17:13:44]
        - Verifies that a correctly formatted system serial number has been burned into the unit.
        [16:22:42] Test Passed
        [06/22/20 16:22:42] * All startup tests passed [Elapsed time = 00:00:00] *
        [06/22/20 16:34:10] * TESTING STARTED *
        [06/22/20 16:34:10] Boot ROM: Boot ROM FW GUID MAC Addr Checksum Test (test #2) - Boot ROM FW GUID MAC Addr Checksum Test
        - Verify the Boot ROM FW GUID MAC address checksum.
        [16:34:10] Test Passed
        [06/22/20 16:34:16] Sensor Group (test #5) - Limit with Core Load Test
        - Verifies a group of sensors defined in SensorGroupLimits.prm. The test will generate two loads - cpu and gpu - then verify the list of sensors per limits.
        [16:35:08] Sensor Failure=[Current (ID0R) -- DC In] Faild Value=0.008789
        [16:35:10] Sensor Failure=[Voltage (VD0R) -- DC-In] Faild Value=0.000000
        [16:35:10] ERROR -- 3 [Sensor reading below low point] -- TEST FAILED
        I dont know if this errors are problems from board or they are because incompability bios issue. (this board has had spilled coffee in the past)
        At least, seems that pch and smc are not damaged.
        I will test the circuits involved an will post the results.
        • piernov
          • Jan 2016
          • 4437
          • France
          Make sure Magsafe is plugged in properly and there is no bad contact in the connector during the test.
          • Francisco.s
            • 686
            • Spain
            Seems that ASD 3S162 is a bit buggy, as I've read from other forums.
            Finally I have repaired the "ME region" from original dump, and all is working properly.
            ASD 3S162 keeps showing weird errors.
            Some weird errors:
            - Verifies PCIe root port error bits for wireless module doesn't register any NAKs
            [16:41:17] ERROR - -12100 [IOConnect error reading from PCI address space] -- TEST FAILED
            - Checks the SATA link error registers for dropped data packets using direct PCI access.
            [16:41:18] ERROR - -12105 [PCI driver IOService open error] -- TEST FAILED
            - Verifies that a unit can automatically sleep and wake using the OS sleepx tool with 30/60/1 settings.
            [16:48:31] ERROR -- 11 [Invalid wake event] -- TEST FAILED
            These are as an example, but there are a few more.
            So the problem was bios corrupted, but only in ME region.
            Thanks your valuable help.
            • sofles
              Macbook Pro 16" A2141 screen artefacts, kernel panic
              by sofles
              Hi there.
              I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
              I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
              Now situation looks like this, If...
              02-05-2025, 05:05 AM
            • prw07
              MacBook Pro A2141 - macOS Kernel Panic
              by prw07
              Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
              How to localize the problem ?
              12-05-2023, 06:57 AM
            • ronaldopdias
              A1990 Constant Kernel Panic: AMDFramebufferVIB::setPowerState
              by ronaldopdias
              Hi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
              Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura....
              07-07-2023, 01:58 AM
            • tranquility
              Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
              by tranquility
              i want to repair an Onkyo TX-NR809 receiver.
              symptoms:
              on power on, display appears and i hear one click. enue functions is given.
              - no hdmi output
              - audio output not tested, but i think it is not there
              - usb sticks are not recognized
              if i read out the chips with display+standby button + tone+
              both dts show only ????
              chip is D830K013BZKB4
              things i have done:
              - reflow of the dts chip without taking off and reballing
              - changed the aluminium caps without the big one with 25v because i dont...
              Today, 01:04 AM
            • Wachenaggo
              Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
              by Wachenaggo
              I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
              Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
              I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
              I also manage to damage...
              03-29-2022, 07:36 AM
