Thinkpad T450s fails when second battery is inserted.
  • VikingOy
    • May 2020
    • Norway
    Scenario1: No AC attached. Internal Battery (1) charged and connected. External Battery (2) removed = No issues! Boots into windows OK.
    Scenario2: Powered off. Insert external battery (fully charged). No AC connected. PC enter a never-ending boot loop.
    Scneario3: Powered off. Both batteries attached and charged (70-80%). Connect AC. Power on. Everything seems ok. Boots into windows. Runs just fine. Charging icon and battery status in windows taskbar looks good for both batteries. Both are confirmed taking charge as the percentage increase steadily. Device Manager reports everything OK.
    Then I pull the AC plug, and the PC immediately powers off - bang!
    Could it be a Windows driver issue? No. Exactly the same thing happens if I only enter into BIOS, and then pull the plug.
    Then I tried swapping both batteries from another Thinkpad (same model). The problem does not follow the batteries, but remain with my PC.
    Summary: if I just stay away from an external battery - everything works perfectly as normal, with or without AC connected. I can plug and unplug AC while in windows. Everything Ok.
    As soon as a second battery goes in - everything goes crazy like described above.
    Has anyone ever seen anything like this before?
    Does anyone have any good tips on how to dig to the bottom of this problem and find the solution?
    (I have tried all the obvious things like; Remove the internal battery and The CMOS RTC battery, and hold down the power button, and yes, BIOS is updated to the last version).
    It looks to me as if the PC is unable to be powered from the second battery. But why? The battery is brand new and it works ok in another PC (same model).
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Thinkpad T450s fails when second battery is inserted.
    It seems an IC on the laptop's mainboard got defective. If it is possible, do not use the external battery.
    • rumpumpel1
      ThinkPad T490s only starts with battery
      by rumpumpel1
      I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
      If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
      If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off...
      12-02-2024, 01:42 PM
    • bykanovm
      Thinkpad W541 Works from the mains and charges the battery only when it is turned off
      by bykanovm
      Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
      If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
      If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
      even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
      Also, the laptop does not turn on without...
      04-02-2025, 02:45 AM
    • Grafnus
      Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
      by Grafnus
      Hey there,
      first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
      So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
      Specs:
      • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
      • CPU, GPU, RAM work fine (not involved in the Problem)
      So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
      Now I noticed...
      08-06-2025, 11:54 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
