Bios Problem with Asus K52F
  • Pavel37
    • Jun 2020
    • 8
    • France
    Have a little problem with my Asus K52F (with Win 10 x64 installed).
    Yesterday I try to update the Bios with winflash, but a blue screen error is coming (Seems it an "isql" error, but not sure).
    Since the computer start, but no boot...
    It run : hear fan, and Optical "try to read DVD", led from "power button", HDD, and sometimes other, light up but screen stay black (I think i doesn't go until bios). then it stop and reboot, many times.
    I try to download some bios in this forum for it, format an USB Key in fat32 (in my other computer with a linux OS), copy the file "as is", and press "home + ctrl" but with no result except the time before reboot seem "stopped" until I release the "combo buttons" (the usb is powered because the light flashing one time when start the computer).
    I don't find any post with the exactly combo button or the procedure to "recover" the bios on this model.
    Do you have any idea ? Do a USB bootable DOS ? Rename file ? Other ?
    Best regards
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Bios Problem with Asus K52F
    now you have to desolder the bios IC and reprogram it using an external programmer.
    • Pavel37
      • Jun 2020
      • 8
      • France
      How to be sure that is only the solution ?
      Because in some tutorial the procedure to recovery the bios is rename the file, but all file here have a different name, what is the good name, and the good format for the usb Key ?
      Only Fat 32 ? or need DOS Bootable ? Or Fat 16 ?
      And the name of the file ? K52F.bin ? K52F.BIN ? K52FAS.bin ? other thing ?
      I would be sure I Have not an other solution before reflash with programmer because i don't have the material and no knowledge to do this...
      thank's
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        It is possible that some bios recovery method works too. To do that, you should study bios recovery methods of Asus laptops from the net and try them out.
        • Pavel37
          • Jun 2020
          • 8
          • France
          Yes, that is what I post here : I don't find anything for K52F, that is the reason why I need help from someone have any procedure who work on this model, or similar...
          • Pavel37
            • Jun 2020
            • 8
            • France
            Nobody have idea ?
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Looks like Windows said "IRQL_NOT_LESS_OR_EQUAL", which is a sign of CPU instability. Possibly bad SMD caps. (if the code is 0x0000000A)
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                how can we find which SMD capacitor is defective or weak?
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  If the CPU SMD cap manufacturer, is NEC/Tokin, then they are automatically suspect!
                  Arc A770 16 GB
                  • Pavel37
                    • Jun 2020
                    • 8
                    • France
                    Thank's for your reply, and sorry for my tardiness answer.
                    If I understand what you say, that is my problem is caused by other thing that a bad bios ?
                    Can I change the CPU SMD ? And how to identify it on the motherboard ?
                    Thank's
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      clearly its a bios problem like caspian said... try to connect an external monitor to your unit.. then power on..try to see if it can boot to external nonitor. if you can do so try to reflash you bios with new bios dump.. maybe the computer encounter an error on writing to the bios that render you with a brick laptop.. i have the same problem with lenovo laptop costumer tried to update the bios but the unit suddenly turn off in 35% update status.. then when he reboot it.. blank screen cpu fan spin.. hard drive makes the initial step noise... i only reflash it..
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        "IRQL_NOT_LESS_OR_EQUAL" is also a problem of bad hard drive and bad memory.. it is short for blue screen of death..
                        • Pavel37
                          • Jun 2020
                          • 8
                          • France
                          Thank's for your answer. I will try it and do a report quickly
                          • Pavel37
                            • Jun 2020
                            • 8
                            • France
                            Connecting an external monitor not work.
                            I'll go to a specialist for the reflash bios/replacement EEPROM because i'm not too good for this.
                            • Sebastian Codrean
                              BIOS file for ASUS F542UN laptop
                              by Sebastian Codrean
                              Hello to all of you! I need help with a BIOS file.
                              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                              02-20-2025, 10:25 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • futadmytro
                              Asus g713qm-es94 stuck on boot bios problem
                              by futadmytro
                              sn^M4NRKD02753616E
                              MB- g533-6050a3250201-MB-A03
                              Stuck on boot after ROG logo, did not enter to bios
                              In flash bios , laprop boot but have video issue
                              orig bios...
                              06-25-2025, 08:07 AM
                            • grimacelord
                              by grimacelord
                              07-10-2025, 02:52 PM
                            • caglarec2268
                              Asus X515EA Bios File Please
                              by caglarec2268
                              merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                              Now "please follow the steps below to recover your bios" text remains on the screen
                              I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                              laptop model x515ea-bq945w
                              s/n: R4N0CV02K527148
                              CN:HWFB
                              Board model; ASUS X415EA R7.0
                              bios chip: GD25Q128...
                              11-27-2024, 03:51 AM
