lenovo b470 turns on only on battery
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: lenovo b470 turns on only on battery
    ok i try to removed pq4002
    • String2016
      • Nov 2015
      • 2238
      • philippines
      removed pq4002 plugged both charger and battery pin 7 have voltage of 3.3v
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Any news ?
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Ok good put it back PQ4002
          And TELL ME WHAT VOLTAGES YOU ARE GETTING ON
          PU4001
          DRAIN = ?
          GATE = ?
          SOURCE = ?
          AFTER PLUG IN CHARGER
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            If you will reply like this than it will take 2 days to fix it
            • String2016
              • Nov 2015
              • 2238
              • philippines
              #26
              sorry for the late response on the pu4001 SOURCE have 19v and GATE=19 but DRAIN=0V no voltages on the drain with charger only plugged in
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                #27
                Do you have WhatsApp
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  #28
                  Check pq4001 pin no:- 5 = ?
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    #29
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      #30
                      pq4001 pin 5 have 3.3v sorry i dont have whatsapp number
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #31
                        Ok
                        Check RASISTOR VALUE
                        PR4002
                        PR4003
                        • qayyum786
                          • Aug 2018
                          • 1959
                          • INDIA
                          #32
                          Stay in touch continue till we fix this issue
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            #33
                            pr4002 = 100kohms pr4003= 49.58kohms
                            • qayyum786
                              • Aug 2018
                              • 1959
                              • INDIA
                              #34
                              Remove PQ4001and make jumper from pin 3 to pin 4
                              • qayyum786
                                • Aug 2018
                                • 1959
                                • INDIA
                                #35
                                Any good news
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  #36
                                  ok thanks ill update later
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    #37
                                    Ok
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      #38
                                      update: @gayyum786 my mistakes of measurements here is the correct measurements on pq4001 6pin chip pin 1=19v pin2=3.3v pin 3 to pin6 both 0v
                                      • qayyum786
                                        • Aug 2018
                                        • 1959
                                        • INDIA
                                        #39
                                        Give ne value of pr4001 rasistor
                                        • qayyum786
                                          • Aug 2018
                                          • 1959
                                          • INDIA
                                          #40
                                          How come pin 1 is connected to the GROUND
                                          i think you are masure from pin 6
                                          • Zentech
                                            Lenovo Thinkcentre Turns On When Power Cord Plugged in
                                            by Zentech
                                            I got a Lenovo Thinkcentre MT-3218 that when I plug the power cord, the computer turns on. The power button seems to work just fine. When I press it the computer turns off, and when I press it again, it comes back on. But when I unplug the power, and plug it back again, it turns the computer on... does anyone have an idea what might be causing this strange behavior. Could this be the power supply or a bad contact on the power button?
                                            thanks
                                            PS: everything else on the computer works fine
                                            06-27-2021, 12:30 PM
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • twonk9098
                                            Lenovo Legion 5 high fan spin turns off after 34 seconds
                                            by twonk9098
                                            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                            I have tried a few new bios but exactly...
                                            07-14-2024, 11:19 AM
                                          • keepread
                                            Lenovo Ideapad S400 turns off when booting into any OS desktop
                                            by keepread
                                            I've been using this laptop for quite some time w/o battery. It has Linux installed. Recently, someone sent me a web link in an instant messenger. When I clicked on that link the laptop turned off that instant, before the browser even loaded to open it. Since then it turns off several seconds after I start it up and log into the Linux graphical desktop. I can see the mouse cursor moving around the screen when I draw my finger on the touchpad or move the mouse, and then a terminal window begins to load because the desktop autostarts it from last time, and then I hear a pop from the speakers and...
                                            12-18-2024, 08:32 AM
                                          • zatara10
                                            Lenovo B580 - unauthorized wireless network card is plugged in. power off and remove it
                                            by zatara10
                                            lenovo B580 change wifi card after this error "unauthorized wireless network card is plugged in. power off and remove it"
                                            bios dump attached...
                                            08-24-2024, 03:06 AM
