MacBook Pro A1278
  • tintin007
    • May 2020
    • 11
    • nz
    MacBook Pro A1278
    I have the right boardview and schematics from this site, Pretty sure i have a sensor issue. Could someone share the ASD 3s155 with me so i can run the tests ?? Prefer .rar format. Cheers
  • Stratos
    • Sep 2015
    • 18
    • Greece
    Re: MacBook Pro A1278
    hello,what symptoms you have?loud fan and slow cpu speed?
    • tintin007
      • May 2020
      • 11
      • nz
      yes pretty much that. loud fan, very sluggish, kernel task 200+%, took a long long time to re install OS
      • Stratos
        • Sep 2015
        • 18
        • Greece
        i have in the pass the same on macbook pro 13 mid 2010.
        before look for problem on hardaware you must know this is what macbook pro do in some cases without battery.
        your battery is ok?
        • Stratos
          • Sep 2015
          • 18
          • Greece
          my macbook under this conditions took 24 hours to instal os!
          try this https://www.youtube.com/watch?v=N5o1-7OuO8A
          if you have problem to delete the file you do this https://www.youtube.com/watch?v=_YmcjqkpI4A&t=44s
          • tintin007
            • May 2020
            • 11
            • nz
            Hi Stratos, Battery is ok. charges up to full capacity, according to display. using mac charger and led changes from amber to green. I tried the other you tube fix before posting, It didn't make any difference at all. Hence why i think its a hardware issue. Its a mid 2012 from what i understand
            • luckydip
              • Aug 2016
              • 159
              • uk
              A couple of things to check:
              see if removing the webcam cable makes any difference - clean/check soldering on connector
              check around the SMC for corrosion
              remove battery level indicator cable and test
              check trackpad cable/connector for corrosion
              • tintin007
                • May 2020
                • 11
                • nz
                I have a resolution. I found some corrosion on pin 2 of r5054, Replaced r5054 as it was open. also cleaned corrosion around pin 2. Macbook now runs happily. Looks like this goes to a bi line on the CPU_PECI. Cheers for your advice
                • Adogabriel100
                  Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                  by Adogabriel100
                  Hey! This is a A1278 macbook 2011.
                  Problem: Not turning on / No green light
                  Im using by3200s charger.
                  Voltajes:
                  PPBUS_G3H = 12.26v
                  SMC_RESET_L = 3.3v
                  PP3V42_G3H = 3.42v
                  U7000 =
                  Pin 1 CHGR_AGATE = 0v
                  Pin 2 CHRG_DCIN = 19v
                  Pin 3 CHRG_ACIN = 4.6v
                  Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                  Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                  Pin 12 PP3V42_G3H = 3.42v
                  Pin 13 CHRG_RST_L = 3.3V
                  Pin 14 SMC_BC_ACOK = 0.8V
                  Pin 19 PP5V1_CHRG_VDD = 5.05V
                  Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                  04-01-2024, 01:02 PM
                • Rezendes
                  Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                  by Rezendes
                  Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                  I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                  The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                  05-10-2024, 02:18 PM
                • pcbmaniac
                  MacBook A1278 (3115) No PPBUS_G3H Issue
                  by pcbmaniac
                  Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                  I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                  1. U7000 Measurements:
                    • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                  2. Resistors:
                    • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                  Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                  • If I also decide to replace the SMC, do I need to order it pre-programmed,
                  12-02-2024, 04:12 PM
                • sizar00740
                  macbook pro 13 inch a1278 820-2879
                  by sizar00740
                  please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                  07-30-2025, 10:21 AM
                • envym
                  by envym
                  Hi everyone!
                  06-27-2025, 08:54 AM
