Macbook Pro 2012 Greenlight but not Power On
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi gooday i have a very technical issue here with a Macbook pro 2012 820-3115-B which is gives me a greenlight but no fan spin and doesn't seem to power on.On my bench power supply i get a reading off 19v 0.15 A and it stays there..I have checked for all major voltage requirements and most of them are present..I even have another identical working board that i use to compare voltages.But i still can't figure out the issue..Can u guys please help me maybe trace it down? I have all tools to remove and also measure ics and capacitors..Thanks
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Pro 2012 Greenlight but not Power On
    Go down the list of power rails on the schematics and list all voltages.
    Also history of the machine always give hints.
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      Ok sir i have attached all the voltages listed below...Funny enough while going tru the first set of voltage testing i noticed the Power Supply only drawing 0.01 Amps which is strange..Because before i was getting 0.14A and some of the voltages which are now 0v was giving me readings..Weird..But the history of this machine is that it came in from a friend for both usb ports not working..Everything else was functioning properly and working..I removed and replaced U4600 from a donor board ..I powered it up and while it was booting the whole system just shut off...And that was when i started having this no power issue..So as of now it gives me intermittent greenlight..It stays on green for 5 seconds then goes..And comes back after 60 seconds then goes..now it's drawing 0.01A
      PPBUS_G3H =12v
      PPBUS_S5_HS_COMPUTING =12v
      PPBUS_S5_HS_OTHER_ISNS = 12v
      PPDCIN_G3H = 19v
      PP3V42_G3H = 3.42v
      PPVRTC_G3H = 3.45v
      PP5V_S5_P18V5S5_VIN = 5v
      PP5V_SUS = 0V
      PP5V_S0 = 0v
      PP3V3_S5 = 0v
      PP3V3_SUS = 0v
      PP3V3_S4 = 0v
      PP3V3_S3 = 0v
      PP3V3_S0 = 0v
      PP1V8_S0 = 0v
      PP1V5_S3 = 0v
      PP1V5_S3RS0 =0v
      PP1V5_S0 = 0v
      PP1V05_SUS =0v
      PP1V05_S0 = 0v
      PPVCORE_S0_CPU = 0v
      PPVCORE_S0_AXG = 0v
      PP1V5_S3_CPU_VCCDQ = 0v
      PP1V05_S0_CPU_VCCPQE = 0v
      PP1V8_S0_CPU_VCCPLL_R =0v
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • platinumsteel
        Macbook pro 2012 820-3115-B Greenlight no Power on
        by platinumsteel
        Gooday people i have a 820-3115-B Macbook pro 2012 that gives me greenlight but does not power on...History of the machine was there was no green-light and dead.And i replaced the ISL chip for brand new 1...Greenlight now but will not power on automatically or fan spin.I checked most of my relevant power rails and i realize that PP5v_S3 is missing...It's drawing 0.02 Amps Possible you guys can help me pinpoint the issue? btw 12.58v on PPBUS_G3H
        08-29-2020, 06:08 PM
