Troubleshooting: Lenovo Motherboard
  • kiraro
    • Jan 2016
    • 177
    • North NY
    #41
    Re: Troubleshooting: Lenovo Motherboard
    check PR329(47k) PR330(10k) PR331(10K) PR332(12K),after that check BQ24737_VDD voltage present on pin 1 of PR330 !!
    • kiraro
      • Jan 2016
      • 177
      • North NY
      #42
      and voltage of both side of PR 330?
      • DanFen
        • Apr 2017
        • 201
        • Malta
        #43
        Hi kiraro thanks for your help!
        First of all, it's really difficult to find where these resistors are located. I hope I am tracing them correctly I managed to locate two of them, but not sure how I'm able to locate the others (most probably they are somewhere else on the board). I'm attaching a photo.
        Based on the photo:
        PR329: 47k
        PR330: 10k (0V on both ends)
        PR331: not sure where this is
        PR332: not sure where this is
        This is where BQ24737RGRR is:
        • kiraro
          • Jan 2016
          • 177
          • North NY
          #44
          Originally posted by DanFen
          REGN confirmed 6V. I don't have a DC Power Lab. Tempted to get one, only if I get better with this
          ... I'll get PQ302 out.
          according to this you should get your 6v regn pin16 = BQ24737_VDD in the first side of pr330 (10k) and also you will get this voltage 3,2v (voltage divider : 6*(12/22) )on second side because also you said there is 0v on all pins of pq309 that mean gate pin 5 =0v so the voltage in the output of pr330 will not drop to zero( just will be dropped even gate get 0v in case of pq309 faulty )and you will get pacin voltage output ,if there is no voltage on pr330 trace the track to the pin 16
          • DanFen
            • Apr 2017
            • 201
            • Malta
            #45
            Assuming that PR330 is actually the resistor I found, it has 0V in and out.
            And correct, double checked PQ309, 0V on all pins.
            It's going to be difficult to trace the components back to the IC. I can test out the components that seem to be on the track of pin 16 of the IC that are shown in the photo in my previous post.
            • DanFen
              • Apr 2017
              • 201
              • Malta
              #46
              This is just a random check. Is a reading of 105 ohms on a resistor that has 100 on it normal. Shouldn't that be 10 ohms? This seems to be PR309.
              • kiraro
                • Jan 2016
                • 177
                • North NY
                #47
                mesure resistance between pin 3 pq309b and regn pin16 = BQ24737_VDD?
                • DanFen
                  • Apr 2017
                  • 201
                  • Malta
                  #48
                  234 k ohms
                  • kiraro
                    • Jan 2016
                    • 177
                    • North NY
                    #49
                    that mean pr330 faulty or open , try to find it with continuity mode between pin 16 and resistance around pq309 ,and second side connected to pin 3 of pq309
                    • DanFen
                      • Apr 2017
                      • 201
                      • Malta
                      #50
                      This is tricky for me. So if I understood correctly, if I switch to continuity mode, there should be beeping between PIN 16 BQ24737_VDD and PIN 33 PQ309B? If this is the case, then there is not.
                      • kiraro
                        • Jan 2016
                        • 177
                        • North NY
                        #51
                        beeping with the first side of pr330 and the second side of pr330 beeping with pin3 pq309
                        pin16->first side pr330 beeping , second side pr330 -> pin3 pq309 beeping after find it measure her resistance that should be 10k if it's open or very hight value change it with another 10k resistance
                        when find pr330 try to find the second part of the voltage divider pr332 12k,first side beeping with pin3 pq309 and second side beeping with ground ,check value.
                        • DanFen
                          • Apr 2017
                          • 201
                          • Malta
                          #52
                          thanks
                          So, continuity between:
                          PIN 3 PQ309 & PR330 first side = beep
                          PIN 3 PQ309 & PR330 second side = no beep
                          PIN 16 BQ24737_VDD & PR330 = no beep
                          Resistance on PR330 is 10k
                          I'll try to find PR332.
                          • kiraro
                            • Jan 2016
                            • 177
                            • North NY
                            #53
                            that should beeping between pin 16 and first side pr330 ,first or second side ,the important that should beeping at one of them and the other side should be beeping with pin 3 pq309
                            • kiraro
                              • Jan 2016
                              • 177
                              • North NY
                              #54
                              don't confuse pr330 and pr331 ,they are two with same value 10k
                              • DanFen
                                • Apr 2017
                                • 201
                                • Malta
                                #55
                                In this case it doesn't beep from PIN 16 to PR330.
                                First side of P330 beeps with PIN 3 PQ309.
                                PR332 is probably the resistor that is located just underneath PR330 in the photo I've posted earlier. You're right, it is 12K and the first side beeps with PIN 3 of PQ309 and the second beeps with ground.
                                • DanFen
                                  • Apr 2017
                                  • 201
                                  • Malta
                                  #56
                                  Very difficult to see, however the track is visible between PQ309 PIN 3 and a resistor, and I've concluded that it's PR330 (is it a good method to find components?). I am not sure where PR331 is.
                                  • kiraro
                                    • Jan 2016
                                    • 177
                                    • North NY
                                    #57
                                    to verify it's pr330 or not :
                                    pr331 is connected to pin 2 of QE2 (ACIN) If there is continuity to this pin so it's pr331, if not so it's pr330 ,best method it's with board view but sorry I don't have it .
                                    in case it's pr330 and no continuity to pin 16 that mean the track is bad and you should make a jumper from pin 16 ( don't solder directly to the pin, you can solder on the pin 2 of pd303 ) to pr330 (side that it's not connected to the pin 3 of pq309 ) , with this you will have pacin signal and your 19v will come out .
                                    • DanFen
                                      • Apr 2017
                                      • 201
                                      • Malta
                                      #58
                                      This is even trickier than I thought, the pins on the Datasheet of QE2 are different than the numbers on the schematics! But I'll follow datasheet because it explains the pins on a picture.
                                      There is continuity between PIN 2 QE2 (which according to datasheet is source) to what I think is PR331.
                                      There is continuity between PIN 1 QE2 (which according to datasheet is ground) to what I think is PR330.
                                      Boardview would have helped unfortunately I couldn't find it. Probably does not exist.
                                      • kiraro
                                        • Jan 2016
                                        • 177
                                        • North NY
                                        #59
                                        what about the fourth resistance below PR329 it's not pr330? (in your picture post 43# )
                                        • DanFen
                                          • Apr 2017
                                          • 201
                                          • Malta
                                          #60
                                          Hmm, that is a possibility. It's also 10k. But that still has no continuity to PIN 16. An no continuity to QE2.
                                          • andrhouseolly
                                            Lenovo X240 - motherboard replacement for X250, no image.
                                            by andrhouseolly
                                            Friends. I beg you to help me in this situation.
                                            Lenovo X240 with a video problem. Native Intel drivers are not installed,
                                            after installation, a black screen. It works with the standard Microsoft driver.
                                            Understanding that there are problems with the video core,
                                            I ordered a motherboard from Lenovo X250.
                                            The laptop turns on, starts up, there is no image on the internal display.
                                            The image is output to the external monitor.
                                            I ordered another motherboard from Lenovo X250.
                                            07-12-2024, 03:02 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • Bob_Crachet
                                            Some help with troubleshooting a HP ProDesk 400 G2.5 SFF motherboard please
                                            by Bob_Crachet
                                            I am experiencing the following symptoms:
                                            With the device fully assembled when I press the power button, nothing happens at all.
                                            I pulled the power supply from the computer and stuck a paperclip into pins 16 and 17 on the connector causing the power supply to turn on and the fans to start spinning. All of the voltages checked out ok.
                                            With the power supply outside of the case, I plugged it back into the motherboard and tested it again. No change. PC did not turn on.
                                            I put my multimeter in continuity mode and put the black probe on one...
                                            05-09-2023, 06:28 PM
                                          • claws77
                                            lenovo flex 5 14ITL05 bios and motherboard fault
                                            by claws77
                                            my laptop is lenovo flex 5 14ITL05
                                            recently my power supply for this laptop developed a fault.
                                            which caused a short in my usb c port -- verified with a new charger.
                                            rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                            I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                            07-05-2024, 04:33 PM
