Troubleshooting: Lenovo Motherboard
  • kiraro
    • Jan 2016
    • 177
    • North NY
    #81
    Re: Troubleshooting: Lenovo Motherboard
    that very low value for +1,35v line , check pq501 and pq502
    • DanFen
      • Apr 2017
      • 201
      • Malta
      #82
      I have a hard time testing these mosfets Resistance measurement keeps increasing forever or keeps decreasing forever or else it just changes value like crazy (since I have it set on auto range, sometimes it even switches between kohms and mohms). Can't understand why this happens. Maybe I'm just doing something wrong.
      I am just trying to follow this. Is this the correct way or am I getting crazy?
      1. Black on Source and Red on Drain
      2. Red to Gate momentarily
      3. Black on Source and Red on Drain
      EDIT: Probably red should be on source (checked the diode symbol here)
      In the meantime I've measured the voltage:
      PQ501:
      D > 19V
      S > 0V
      PQ502:
      D > 0V
      S > 0V
      • kiraro
        • Jan 2016
        • 177
        • North NY
        #83
        when power on check +3VALW_SOC (Q26 pin1 -Drain) +1.0VALW (PJ702) +1.8VALW (pj602) VR_+1.0VALW_PWRGD (pin 5 of PU701 )
        and SYSON signal on PU501 pin 16 (S5)
        with simplicity :
        N-channel : (diode mode)
        1-red (source),black(drain) 0500~0600
        2-black(source),red(drain) Open
        3-and test if source and gate short together or not
        P-channel : (diode mode)
        1-red (drain),black(source) 0500~0600
        2-black(drain),red(source) Open
        • DanFen
          • Apr 2017
          • 201
          • Malta
          #84
          Thanks for the clarification
          +3VALW_SOC (Q26 pin 1 - Drain) = 3.3V
          +1.0VALW (PJ702) = 1V
          +1.8VALW (PJ602) = 1.8V
          VR+1.0VALW_PWRGD (PU701 pin 5) = 3.3V
          SYSON signal on PU501 pin 16 (S5) = 0V
          PQ501 (n):
          Source (red) to Drain (black) = 0.554
          Source (black) to Drain (red) = 2.9
          no cont between gate and source
          PQ502 (n):
          Source (red) to Drain (black) = 0.08
          Source (black) to Drain (red) = 0.370
          with simplicity :
          N-channel : 1-red (source),black(drain) 0500~0600
          P-channel : 1-red (drain),black(source) 0500~0600
          • kiraro
            • Jan 2016
            • 177
            • North NY
            #85
            check pj201 +20VSB (pin1 PQ210)
            • DanFen
              • Apr 2017
              • 201
              • Malta
              #86
              19v
              check pj201 +20vsb (pin1 pq210)
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                #87
                Syson and susp# are the enable signals for PU501.
                Syson enable Pu501 to generated 1.35V. Susp#enable Pu501 to generated 0.675V.
                In the power sequence , before this steps (suson and susp#) we have to check PM_SLP_S3# and PM_SLP_S4# at UE1 pin 18 and 21.
                • kiraro
                  • Jan 2016
                  • 177
                  • North NY
                  #88
                  - UE1 Pin93 EC_RSMRST#
                  -all pins voltage QC11 and QC12
                  • DanFen
                    • Apr 2017
                    • 201
                    • Malta
                    #89
                    UE1
                    Pin 93 (EC_RSMRST#) = 3.3V
                    QC11
                    Pin 1 = 0V
                    Pin 2 = 1.7V
                    Pin 3 = 0V
                    Pin 4 = 0V
                    Pin 5 = 1.7V
                    Pin 6 = 0V
                    QC12
                    Pin 1 = 0V
                    Pin 2 = 1.7V
                    Pin 3 = 3.3V
                    Pin 4 = 1.7V
                    Pin 5 = 1.7V
                    Pin 6 = 0V
                    • DanFen
                      • Apr 2017
                      • 201
                      • Malta
                      #90
                      Those are both 0V
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        #91
                        It seems that your S3 state won't be complete ,did PU501 get hot ! try to use a good known ram (DDRL)
                        What's the voltage on pin 12 !
                        Try to flash your bios .
                        • DanFen
                          • Apr 2017
                          • 201
                          • Malta
                          #92
                          No it's not hot. Voltage on Pin 12 of PU501 is 5V.
                          EDIT: Tried good known RAM and still the same. It turns on, and turns off after ~2 sec. There's a click when it turns off. I also don't have the tool to flash the BIOS chip.
                          • DanFen
                            • Apr 2017
                            • 201
                            • Malta
                            #93
                            In such case, since it's not a high end motherboard, I think it makes more sense to simply order another one.
                            Just want to thank all of you guys who supported me with this, I definitely learnt some new stuff
                            • andrhouseolly
                              Lenovo X240 - motherboard replacement for X250, no image.
                              by andrhouseolly
                              Friends. I beg you to help me in this situation.
                              Lenovo X240 with a video problem. Native Intel drivers are not installed,
                              after installation, a black screen. It works with the standard Microsoft driver.
                              Understanding that there are problems with the video core,
                              I ordered a motherboard from Lenovo X250.
                              The laptop turns on, starts up, there is no image on the internal display.
                              The image is output to the external monitor.
                              I ordered another motherboard from Lenovo X250.
                              07-12-2024, 03:02 PM
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • Giggle2562
                              Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                              by Giggle2562
                              I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                              The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                              Here's what I've tried so far:
                              • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                              • The laptop shows an image on the internal display for a few seconds before it shuts down.
                              • I tried swapping the LCD panel with a known good one.
                              • I tried swapping the LCD cable
                              11-06-2025, 12:36 PM
                            • to5it0
                              by to5it0
                              10-24-2025, 01:35 AM
