MacBook Pro
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    MacBook Pro
    Hello My Brothers i salute the divinity in You all, please i really need this help i have this Macbook pro 2019 model FCC ID BCGA1990 /IC:579C-A1990 /C02XJ9BTJG5H which i need Efi password remove please any one here should help a brother please.....Thank you
  • peste
    • Dec 2016
    • 12593
    • ROMANIA
    Re: MacBook Pro
    try this..
    https://www.youtube.com/watch?v=w3TRog3kaSg
    https://www.youtube.com/watch?v=E3UoDLkYZS8
    • piernov
      • Jan 2016
      • 4435
      • France
      Re: MacBook Pro
      MBP 2019 has T2. You cannot remove EFI password without knowing it. You have to go to Apple with proof of purchase.
      • borbooroski
        • Mar 2014
        • 177
        • Ghana
        Re: MacBook Pro
        wowww this too much for me to carry any help to it please?
        • Pedro147
          • Sep 2016
          • 157
          Re: MacBook Pro
          Piernov just told you only Apple can help you if the computer is legitimately yours
          My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • obelix24
            A2941 Macbook air 15” - 5V 0a
            by obelix24
            I’m working on one macbook air 15” m2 that was water damaged.
            keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
            i’ve put macbook in shelf and order new screen so i can fully repair it.
            Now i got the screen and macbook stays at 5v 0a.
            i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
            i don’t have schematics so i don’t know where to start can someone help me?...
            03-27-2025, 01:19 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
