Hello My Brothers i salute the divinity in You all, please i really need this help i have this Macbook pro 2019 model FCC ID BCGA1990 /IC:579C-A1990 /C02XJ9BTJG5H which i need Efi password remove please any one here should help a brother please.....Thank you
					MacBook Pro
	Tags: None
 Re: MacBook Pro
 try this..
 https://www.youtube.com/watch?v=w3TRog3kaSg
 https://www.youtube.com/watch?v=E3UoDLkYZS8Last edited by peste; 03-01-2020, 03:29 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Re: MacBook Pro
 MBP 2019 has T2. You cannot remove EFI password without knowing it. You have to go to Apple with proof of purchase.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
 Re: MacBook Pro
 Piernov just told you only Apple can help you if the computer is legitimately yoursMy YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SAComment
			by envymHi everyone!
 I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM
			by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
 - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
 - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
 ...08-30-2025, 10:27 AM
			by tobeend1. RESET MACOS WITH IPSW
 a. Power off MacBook, press and hold the power button to enter Recovery
 b. Open Disk Utility, remove Macintosh HD
 c. Reboot, connect to the network to Activate Mac.
 d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
 d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
 e. Release the other keys, but keep holding the Power key for another 10 seconds
 f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
			by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?- PPBUS_G3H (12.6V-12.8V)- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)- This
			by obelix24I’m working on one macbook air 15” m2 that was water damaged.
 keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
 i’ve put macbook in shelf and order new screen so i can fully repair it.
 Now i got the screen and macbook stays at 5v 0a.
 i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
 i don’t have schematics so i don’t know where to start can someone help me?...
- Loading...
