Desperate for battery/charge help for Asus N752V
  • MallorcaNick
    • Feb 2020
    • 9
    Hi all.
    My Asus N752V is about 3 years old, had a little upgrade with an SSD installed and works very very well.....apart from a huge battery/charge issue.
    - It only works when plugged in.
    - Bottom right says "0% available (plugged in, charging)....but it's not actually charging at all. If I remove the cable, it switches off immediately.
    - I replaced the battery with a new one, but no difference.
    - It turns itself off after about 2 hours (and doesn't overheat).
    - I've had all tests and diagnostics done via an amateur computer 'fixer' but he came up blank.
    - All drivers etc have been re-installed or changed.
    - I've tried holding down the on/off button for 60 seconds and most of ideas that I've read online.
    Has ANYONE else heard of this issue please? It's driving me crazy!!
    THANKS IN ADVANCE!
    Nick
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Desperate for battery/charge help for Asus N752V
    Did it run from the "new" battery with AC adapter disconnected and did the battery discharge properly?
    • MallorcaNick
      • Feb 2020
      • 9
      I'm not very computer-literate so not sure if I understand.
      It didn't work without the adapter plugged in after the change of battery or before the change. Obviously it worked for 3+ years before it suddenly started playing up......
      • piernov
        • Jan 2016
        • 4435
        • France
        "new" battery probably bad.
        • MallorcaNick
          • Feb 2020
          • 9
          So the old battery was bad and the new battery is bad too?
          I doubt that's the reason.
          Anyway, if there was no battery, just power via the adapter, why would the computer turn itself off every two hours? It's not get warm at all, so it's not heat-related.
          • piernov
            • Jan 2016
            • 4435
            • France
            Market is filled with garbage batteries, it's not uncommon to buy a "new" one that just doesn't work, sometimes 2 in a row (or 3…). New batteries should come charged at around 50% (or at least between 20% and 80%), so laptop should work from it even if it cannot charge it.
              • 20775
              Try batteryMon software, see if it will see the batteries.Click the battery icon on the top left, post some pictures of the results screen.
              • petehall347
                • Jan 2015
                • 4426
                did it work before the upgrade ? if so i suggest trying old drive back in,
                maybe screws in wrong holes
                • MallorcaNick
                  • Feb 2020
                  • 9
                  Thanks. I'm running this at the moment although it's run 600 samples and there's absolutely zero on the screen to look at. How long does the full scan work for please?
                  • MallorcaNick
                    • Feb 2020
                    • 9
                    Yes, it did.....and it worked for a good length of time after the upgrade too.
                    The old drive is still there, but an additional SSD was added, I think.
                    • MallorcaNick
                      • Feb 2020
                      • 9
                      As you can see from the attached screenshot, nothing is showing at all. I've also added the info about my battery taken from the scanner.
                      I really don't know if it's a faulty battery or some other issue.
                      • MallorcaNick
                        • Feb 2020
                        • 9
                        Has nobody got any ideas????
                          • 20775
                          Can you post some good clear pictures of the battery connection area and surrounding components .
                          • MallorcaNick
                            • Feb 2020
                            • 9
                            I haven't got the back off the computer right now.......
                            • techfreak9356
                              Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                              by techfreak9356
                              09-14-2023, 11:10 PM
                            • razenxd
                              How can I charge that battery pack?
                              by razenxd
                              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                              Now, I have noticed a few things.
                              The "dead" battery, while connected to charger and NOT Charging will...
                              12-05-2024, 06:11 AM
                            • ruletero
                              Acer a515-43 low battery charge voltage
                              by ruletero
                              Hi
                              Acer A515-43
                              LA-H801P
                              Fail: Does not charge battery, has low voltaje on connector.
                              Laptop didn't want to turn on, only charge led blinked.
                              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                              10-24-2022, 02:31 PM
                            • dhenion
                              Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                              by dhenion
                              I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                              The original board was:
                              ASUS X510UNR REV 3.0 A
                              The replacement board is:
                              ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                              It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                              01-30-2024, 01:45 PM
                            • Klevjetack
                              Charge a L19D3PDA battery externally from the laptop
                              by Klevjetack
                              Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                              03-05-2024, 07:26 AM
