Hp g62-a153e0
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    Hp g62-a153e0
    G62-A153E0
    PM_A_HPC_S MV_MB_V1
    This computer doesn't display,....
    power up, fan works then off and works normal,
    all volts are ok: 5v 3.3v 1.1v and others
    it is AMD with uma
    i reflashed bios with no succes, tried HDMI
    no success
    please help
    i also get the post code 74 on post card tester.
    wifi led is always on, and cannot be switched off
    Caps lock is always off and cannot be on...
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Hp g62-a153e0
    Could be a dead AMD northbridge RS880M 216-0752001.
    • mazloum
      • Sep 2012
      • 499
      • Lebanon
      Re: Hp g62-a153e0
      you are right....
      thank you very much.....:
      i reflow it , and works
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ex250
        Kenwood SW-505D no sound issue and pops from time to time when it works
        by ex250
        Hello mates,
        I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
        It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
        12-29-2024, 03:27 PM
      • eurowill
        a2141 820-01700 internal display not working / external works
        by eurowill
        Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
        Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
        07-23-2024, 10:06 AM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
