toshiba satellite p750 wifi card not working after removing coil to kill dead gpu
  • durstig66
    • Jan 2020
    • Deutschland
    after removing a power choke coil (pl602 in the schematic) to kill the dead gpu that was outputting heat my wifi card stopped working the other mini pcie slot isnt working either even when tying a different network card
    so my question is how do i keep the gpu dead while restoring my mini pcie slots functionality
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • techrepairheide
    Gaming laptop Clevo NH79EP with short on 5VS-rail
    by techrepairheide
    first of all I want to apologize for my bad English, but I try to give my best.
    Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
    For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
    10-13-2024, 02:49 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • chth96
    How can I test coil whether it is really broken or not?
    by chth96
    I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
    I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
    I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
    I want to replace this round black fuse and unidentified coil if it got broken.
    02-20-2024, 01:07 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
