X550cc rev 2.0 hard drive not detecting
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi the problem with this unit is after a day I trued to turn on the laptop the laptop wont detect its hardrive Ive tried also other hard drive but no luck..
    I tried flashing its bios but no luck..
    Those someone have the same problem any suggestion guys
    Ive tessted the SL5101 i dont have +5VS HDD READING reading
  • u666sa
    • Jan 2014
    • 70
    • Russia
    Re: X550cc rev 2.0 hard drive not detecting
    There is a nice utility there in Windows called swupdate by Asus. Asus update.
    It rocks! It udpates everything just fine, until time comes to updating BIOS. Swupdate does not update BIOS correctly and this is a common problem on these notebooks.
    To fix your issue:
    During boot FN + F2 to go to BIOS.
    Go to BOOT options
    Disable secure boot
    For OS Mode selection, select CSM and UEFI OS
    Save changes, and reboot
    Now obviously, this solution might not work for you because you might have a different problem with your notebook. Try and report back.
    P.S. Could you post boardview and schematic so I could download it and add it to my database of boardviews and schematics. Maybe I'll need it in the future.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      To fix your issue:
      Go to BOOT options
      Disable secure boot
      I dont have any boot selection that you have sir
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ODD detecting?? Q5101 gate voltage??
        • u666sa
          • Jan 2014
          • 70
          • Russia
          Check security section. It's there.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            ODD 1-3 pin has 5v reading Im reading 12VS in pin 4 of pq5101
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Thats correct.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                Thats correct.
                What should I do next sir? What im i having this problem
                • Weelcup
                  TopTech
                  • Oct 2017
                  • 302
                  Have you replaced the hdd cable?
                  Do you hear the hdd working. I mean hdd making any sounds when turning the device on?
                  To me, it is very possibly a connection issues.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    Its was fine in the other day then it suddenly keep booting to bios and nothing is wrong with the bios
                    • Weelcup
                      TopTech
                      • Oct 2017
                      • 302
                      One of my customers reported just like your issue with his apple laptop. And it was the cable. But at time I was not expecting it to be the cable at all.
                      You can check the pins from both ends of the cable using the multimeter.
                      It is important to know if the hdd is making any sounds when powering on the laptop though..
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        ive tested the HARDRIVE Cconnector no problems
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          Hi can I just create a JUMPER from from pin 1-3 of Q5101 to PIN 2 of SL5101 ? is it safe?
                          upload pic site
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 302
                            Aha I see. So the hdd in not connected via cable. It is directly connected via socket. So no cable issues.
                            With regard to the short connection. Why dont you just replace the mosfet ?
                            However, try to connect the hdd with out power the laptop. Just measure the resistant on the side that does not get the 5v...
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              10 OHMS risistance
                              • KvnTM
                                • May 2018
                                • 434
                                10 OHMS risistance
                                You got 10 ohm to gnd on the sata connector without a drive plugged in? Thats too low. I'd suspect that small cap right next to the connector. Remove it and measure again! The pads on it look darkened. Something most likely shorted the rail and killed the fet. Also please measure gate voltage on the fet.
                                Do NOT bridge another 5v rail to it. This may cause more damage!
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  Originally posted by kvntm
                                  you got 10 ohm to gnd on the sata connector without a drive plugged in? Thats too low. I'd suspect that small cap right next to the connector. Remove it and measure again! The pads on it look darkened. Something most likely shorted the rail and killed the fet. Also please measure gate voltage on the fet.
                                  Do not bridge another 5v rail to it. This may cause more damage!
                                  thanks sir for the help ive just remove the capacitor then everthuing boots perfectly
                                  • KvnTM
                                    • May 2018
                                    • 434
                                    Perfet. Well done! As always, just a little cap that breaks everything
                                    You can leave the cap unpopulated. It is just for EMI filtering and not important.
                                    • Weelcup
                                      TopTech
                                      • Oct 2017
                                      • 302
                                      Good to hear that the problem is solved.
                                      • kalilinux25
                                        • Mar 2018
                                        • 2089
                                        • ZAMBOANGA SIBUGAY
                                        Im learning a lot here
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • tmcw
                                          PC case - Hard drive rails
                                          by tmcw
                                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                          Now, the case is a CiT Gaming Case, and...
                                          05-22-2022, 12:04 PM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • sureshbobby
                                          Dell Inspiron 1545 not detecting hard drive and dvd drive
                                          by sureshbobby
                                          Hi Techies
                                          Need help and advice on my laptop dell inspiron 1545
                                          any hard drive and dvd not detecting
                                          please help
                                          11-10-2021, 06:43 AM
                                        • ChaosLegionnaire
                                          bug of the month: write caching setting for the hard drive in device manager
                                          by ChaosLegionnaire
                                          i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                                          so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                                          10-06-2019, 01:39 PM
