Complicated E5550, have psid, charger not recognized, wlan and two usb's not working
  • flatline
    • Apr 2019
    • 23
    • united states
    Dell e5550 (LA-A913P).
    Loaded and ran windows fine. Laptop runs fine except for a few things.
    Wifi card not recognized
    Charger not recognized, Have PSID 3.2v at connector. Will run off battery fine.
    USB1 and USB2 Ports not working/no power. (USB3 port works and loaded windows onto sata drive.)
    (PU1) I decided to jump pin3 to pin4 (psid) and charger was recognized and charged the battery.
    But this does not help my wifi and usb ports. It's not the wifi card and the usb ports look fine.
    Also, The power button works as it should, but the little led on the power button doesn't light up, which I find interesting.
  • KvnTM
    • May 2018
    • 434
    Re: Complicated E5550, have psid, charger not recognized, wlan and two usb's not work
    Is 5V Present on the non working USB ports?
    Things to measure:
    Wlan:
    JNGFF1:
    - +3.3V_WLAN
    - WLAN_WIGIG60GHZ_DIS#_R
    - BT_RADIO_DIS#_R
    USB:
    +5V_ALW
    JUSB1:
    - VBUS
    - If VBUS not present: UI1 USB_PWR_EN1#, +USB_LEFT_PWR
    JUSB2:
    - VBUS
    - If VBUS not present: UI2 USB_PWR_EN2#, +USB_RIGHT_PWR
    LED (Assuming LED is named Breath LED in schematic):
    UE2:
    - BREATH_LED#
    JLED1:
    - BREATH_WHITE_LED#
    • sdinelli
      latitude e5550 - no charge- all battery not recognized as genuine
      by sdinelli
      -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
      -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
      -ive tried multiple genuine chargers
      -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
      https://datasheet.octopart.com/ECE50...-147335658.pdf
      does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
      i have two of these same...
      11-14-2021, 09:52 AM
    • Zilicon
      Elitebook 840 G1 HDD not recognized, Please help
      by Zilicon
      Greetings everyone.
      please, help assist me with the above PC problem.
      The boars number is 6050A2559101-MB-A03. The PC does not recognized HDD, neither does it recognized NGFF SSD.
      i discovered that the HDD does not spin.
      there were activities at the SATA connection.
      Pin 2,3,5,6 rises to 400mv then jump to about 4v, again to mv. It continues in loop that way. Same behaviour at pin 20,21,22.
      5v is present at 14,15,16.
      Pin 18 which is reserved has about 1.8v, sometimes it increases to 2v+.
      Pin 8,9,10 is...
      06-16-2025, 12:11 PM
    • martimarti
      RX 6700 XT PowerColor not recognized in any OS
      by martimarti
      The title explains the issue. The additional information is:
      - GPU was never disassembled
      - not recognized in Windows/Linux, not even with error, totally not recognized like it's not plugged in
      - GPU fans don't spin but work. When I turn on the system, the fans twitch for that second when I press the power button. Same thing happens when I power off the system.
      - GPU does not get hot no matter for how long I let it run even though not recognized
      What I have to done so far:
      - played with the BIOS switch without any luck. OC/SILENT...
      03-31-2023, 09:34 AM
    • Carl0s-
      iPad 5th gen (A1823) - No charge but recognized by finder
      by Carl0s-
      Sooo - our IT got a pile of old iPads that the sales guys have been mistreating. These are free for grabs if you want to try to get one working. Thought I'd give it a try - if I get at least some life to I can give to my kid to entertain during a car rides.
      But the iPad it self - its a 5th gen cellular model. When I initially plug it in it was completely dead. It was not recognized by my Mac nor it started to charge. Disassembled it opened up the battery connector and checked the battery voltage. My multimeter showed 0,7v. Had a spare micro-usb charging board lying...
      04-15-2024, 12:51 PM
    • re1nhold
      Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
      by re1nhold
      Hello Guys
      I'm currently fixing two different Dell latitudes,
      I need a E5550 BIOS - SERVICE TAG is: FSFB262
      So far I flashed about 6 BIOS from this forum already,
      none worked,
      only fan spin ~3s, LCD black, keyboard LED on/off ok,
      I tried manual extraction with scripts for ages so to speak. VM is untried yet.
      This laptop is not burnt, it seems to just have a corrupted BIOS.
      I extra baught ram. This has to work friends.
      Do you generate it this way in Windows in CMD?:
      Code:
      E5550A24.exe /writeromfile C:\bios.fd
      07-18-2025, 09:18 AM
