Dell XPS 15 9550 no backlight
  • Karavusk
    • Nov 2019
    • 9
    first of all I am a total noob with board level repair. My Dell XPS 15 9550 backlight died. I tried to replace the screen but it is still not working. I found the schematics online (only for rev 0.0, I have 1.0) but no board view which means I basically can't find anything really on the board. Not to mention that I have never really used a schematic.
    Either way I managed to measure the backlight voltage on the 40pin connector. It is 9mv and supposed to be 25v. Any idea what I should try out next? No matter how much I look at the schematics I don't get any further. The only other thing I managed to do is to look at QV11 pin 1,2,5 and 6 which are also 9mv and probably supposed to be 25v too.
    Here are a few pictures https://cdn.discordapp.com/attachmen...825/image0.jpg
    https://cdn.discordapp.com/attachmen...355/image1.jpg
    The capacitor under Q11 is the only one that looks a bit weird but besides that I found nothing. Any idea what that is used for? Any advise on anything about this is welcome, I have no idea what to do next and I definitely don't have the money to get a new board.
    I hope someone can help me, thanks
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Dell XPS 15 9550 no backlight
    Test QV11 all legs for Voltage pin4 +B 19V (not 25V Volts ) pin3 8-10V it’s a mosfet , there is a voltage divider connected to pin 3 in that way the voltage on pin 4 will switch to the drain side
    • Karavusk
      • Nov 2019
      • 9
      Originally posted by techtiger
      Test QV11 all legs for Voltage pin4 +B 19V (not 25V Volts ) pin3 8-10V it's a mosfet , there is a voltage divider connected to pin 3 in that way the voltage on pin 4 will switch to the drain side
      How do I know which pin is 3 and which one is 4? Also I have just shorted one of the pins next to it to 3 or 4, no idea for just a split second. I hope that didn't make anything worse. I definitely wasn't careful enough and got a short spark between the pins I think. Screen is still on with no backlight.
      One of the pins is at around 13.53v and the other ones are still at around 9mv. The other pin (again 3 or 4) is at 13.48v.
      • Karavusk
        • Nov 2019
        • 9
        I have also managed to measure QV12. It has 2 pins on one side and one on the other side. The left pin is at 3.38v, the right pin is at probably 0mv? Sometimes it shows 0.1mv or 0.2mv and then goes back to 0. The top(or bottom?, the one that is alone) pin shows 0.4mv (constantly).
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Test again with out shorting pins
          • Techtiger
            • Oct 2014
            • 1602
            • france
            What voltage do you get 2 resistance 2 caps
            • Techtiger
              • Oct 2014
              • 1602
              • france
              This voltage is correct for this Fet
              • Karavusk
                • Nov 2019
                • 9
                4 is 13.6v right now and 3 is 13.55v right now. All the other pins are still at like 8.7mv.
                From all sides to ground?
                • Karavusk
                  • Nov 2019
                  • 9
                  Here are all the measurements to ground https://puu.sh/EHeG6/96f5696cc6.jpg
                  Actually the 0v is more like 0.4mv, measured multiple times at that place just to make sure.
                  edit: Right resistor is 382.6Ohm, left one is 99.2kOhm
                  edit2: accidentally swapped the ohm values
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    can you confirm the measurements you have given QV11 with the battrey insert ? if so remove the battrey and test again on pin 3 4 voltage ?, RV120 Resistor or QV11 mosfet is bad test those components with Multimeter with out power QV11 is a P-channel Fet RV120 is a 100K Resistor , if you dont have QV11 replacment you can short pin 4 to 5/6 this is the last option , do a multimeter continuity test from QV11 pin 5/6 to LVDS pin 40 39 38 you should get the Buzzer sound
                    • Karavusk
                      • Nov 2019
                      • 9
                      I don't quite understand what you want me to do. Should I test with or without the battery? Also the left resistor is at 99.3k Ohm. That is pretty much what RV120 is supposed to be and I am fairly sure that this is RV120. I measured points with 0 Ohm resistance between them and found this https://puu.sh/EHfVc/1ecd75c6b8.jpg (all measured without power). From what I can tell the 378 Ohm resistor is supposed to be RV 119 which is supposed to be 1m Ohm?
                      https://puu.sh/EH4PO/88f0016834.png
                      https://puu.sh/EHoGY/edef2df9a6.jpg
                      Maybe I have the wrong schematics (my schematics is rev 0.0 while my board is rev 1.0) but it would make sense to me.
                      edit: I shorted pin 4 and 5 and the backlight actually turned on!!! so what now? Replace the right resistor with 1m ohm?
                      • Karavusk
                        • Nov 2019
                        • 9
                        Ok I did it, it works now the capacitor CV168 was defect. This is what gave me the 378 Ohm. A guy took it off the board for me and now it works. Should I replace that or can I leave it off?
                        • Xenoaeuriix
                          • Dec 2022
                          • 36
                          • Philippines
                          May I know how the capacitor looks like and where it is located. I am a total noob here. I got a replacement lcd thinking it was the lcd but when I got replacemed same issue as your still got no backlight. Mine is different do its using 30 pins edp but same model xps 15 9550. Thank you in advance.
                          • mon2
                            • Dec 2019
                            • 14171
                            What are the white silk screen markings on the logic board?
                            Your unit works ok other than the backlight? Working ok with an external monitor?
                            Perhaps you can see the lcd graphics using a phone in torch / flash light mode on the front of the display to confirm.
                            • mon2
                              • Dec 2019
                              • 14171
                              Found a similar(?) bv file that may help.
                              • Xenoaeuriix
                                • Dec 2022
                                • 36
                                • Philippines
                                I am sorry, I am not really sure what you meant by silk screen marking. Super noob here.
                                __________
                                Yes everething works, I can see it booting up to my desktop and can navigate with the screen it is still there like silhouette. You just to look closely on the lcd.
                                __________
                                Yes thank you that is confirmed, you better see it with flashlight and plugging it to the monitor looks okay too.
                                • mon2
                                  • Dec 2019
                                  • 14171
                                  Share any white text markings on your logic board. This will help to locate the exact schematics /boardview files for your unit.
                                  • Xenoaeuriix
                                    • Dec 2022
                                    • 36
                                    • Philippines
                                    Thanks for the response. Sorry for responding late here. I ended up sending the board back to the seller. the board is pretty toasted there are obvious signs of the previous repair. I did try to test out the panel on a different Laptop and confirmed that the LCD is working okay. The part where you can solder the backlight is already jumpered. Thanks for the help
                                    • HTR-Informatique
                                      by HTR-Informatique
                                      02-09-2025, 06:51 AM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                      DELL XPS 9550 Notebook 15 Specification for Upgrade or Repair
                                      This specification for the DELL XPS 9550 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9550 boardview and 9550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9550 Notebook...
                                      09-06-2024, 07:11 AM
