Acer laptop power on but nothing
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    hi i need help about acer motherboard
    i have
    19v mosfet and cap
    3v coil
    5v coil
    1.3v in ram
    1.01v on proccesor capacitor integrated with gpu and chipset
    3v in power button
    1.8v bios chip
    19v in monitor connector
    i try flash bios too
    2 coil near cpu short to gorund
    before not powering on i replace a mosfet and led comes on
    when i press power button led comes on but nothing happen fan no spinning, no display, it takes 0.006 to 0.007amper
    i will post motherboard model soon
    thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer laptop power on but nothing
    2 coil near cpu short to gorund-You measured in diode mode or resistance mode?? Do the measurement in resistance mode and post here. They will show a low value and that's normal but should'nt be zero in resistance mode.
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      motherboard model z5we3 la-a621p rev 1.0
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        0.03 ohm both
        • Techtiger
          • Oct 2014
          • 1602
          • france
          SOC gives low resistance check the basic requirements of PU801 pin 27 22 21 15 8 2 3 5
          PQ803 pin 2 /PQ801 pin 2 / PU501 pin 10 Supply
          • KvnTM
            • May 2018
            • 434
            • Board Repair
            I assume the two coils you mentioned shorted are PL803 & PL 805 ?
            PL803 = SOC_VNN = iGFX VCore
            PL805 = SOC_VCC = CPU VCore
            Please tell us which coils have a low resistance to gnd.
            • digitalpc
              • Jun 2016
              • 305
              • .DLL
              excatly
              • digitalpc
                • Jun 2016
                • 305
                • .DLL
                i will check tomorrow
                as i remember 3v missing at pu801 and at pin 22 resistor R01 is dead and borken track
                • digitalpc
                  • Jun 2016
                  • 305
                  • .DLL
                  me SIO now is dead
                  kb9012qf any equivalent with this model because i cant find the same
                  • KvnTM
                    • May 2018
                    • 434
                    • Board Repair
                    You'd have to get the chip from a donor board or program a new one yourself.
                    • digitalpc
                      • Jun 2016
                      • 305
                      • .DLL
                      Im try to find anyone from another board, not new.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        If you use the 9012kbc chip from a donor board, you will need to program it as well for which you need a kbc programmer like svod etc. Do you have a kbc programmer??
                        • digitalpc
                          • Jun 2016
                          • 305
                          • .DLL
                          yes i have, but i have a bios chip in motherboard?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            What do you mean?? i could'nt follow
                            • KvnTM
                              • May 2018
                              • 434
                              • Board Repair
                              He might assume that the kbc firmware is stored inside the bios rom.
                              Pretty sure he wouldn't have to program it if he takes one from a exact same donor board.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Seems like your assumption is right but lets wait for his clarification.
