iPad Pro 9.7 - Accidently lifted a pad under Tristar chip. Where does it connect?
  • mattpd
    • Oct 2012
    • 302
    Does the boardview for the iPad pro 9.7 exist?
    I have lifted pad A1 and need to run a jumper.
    The iPhone 6 uses the same chip. On the iphone, the net name is 90_BB_USB_P
    Anyone know where I can connect this pad?
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
  • Aimbit
    Apple iPad Air 2 (A1566) - Seems to be power cycling, no display, new battery/Tristar
    by Aimbit
    Using an ammeter, original battery was only taking 90mA or so... then down to 0, up to 90mA, down to 0, etc, in a repeatable pattern. This iPad was very old, so first thing I did was swap the battery for a good one, and it came pre-charged. The old battery had negligible voltage.
    Now the iPad go up to about 1.5-1.6amps charge, then it drops to 0 after a few seconds... rinse/repeat as before. I tried changing the Tristar chip to see if that would help (and also my first real BGA chip!) but it seems to make no difference. Where should I look next?
    I should poke around the...
    06-29-2024, 09:51 PM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
  • KYBOSH
    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
    by KYBOSH
    I picked this one up today.
    Previous owner says no signs of life.
    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
    The TV model is QN65LS03BAFXZA - version: CB06
    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
    Will keep you all...
    04-05-2025, 08:32 PM
  • An-klamm
    Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
    by An-klamm
    Hello!
    I have a TV that I can't get any further with.
    It is a Samsung UE 55HU8590 with one connect box.
    When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
    As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
    Since the TV works without ocb, I assume that it can't be the PSU?!
    I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
    Is there...
    12-04-2023, 01:35 AM
