Dell Inspiron 3521 want charge battery
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    thats first topic to me,
    my case is with dell inspiron 3521, the laptop work fine, but don't charge the battery.
    first thing i try is changing the battery with new one, same problem.
    i try to change the charger, same problem.
    i try to change the dc jack, same problem.
    try to change bios chips (there is tow bios chips in that motherboard). same problem.
    is there any other ideas?
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: Dell Inspiron 3521 want charge battery
    1st check in bios setup charger show or not?Like 90w,65W Dell many case in ID problem if not show charger then problem in id track id you will know
    • piernov
      • Jan 2016
      • 4439
      • France
      Does it turn on from battery only? Does it report battery percentage correctly?
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        try to scan the motherboard for burned open or shorted mosfets specially in the battery charging section or try to measure the voltages with and without the battery and post the voltage measured here and will try to help you or post some pictures in the battery section.
        • danielsak
          Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
          by danielsak
          Hello, I have issue with Dell Inspiron 3542.
          Motherboard marking:
          Code:
          PWB FX3MC REV: A00
          The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
          1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
          1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
          10-11-2024, 04:36 PM
        • madjid911
          Dell Inspiron 15-3511 NO charge battery
          by madjid911
          Hi, Can you help me on the LAPTAOP Dell Inspiron 15-3511 with motherboard GDM50-LA-L241p, it lights up very well with charger but does not charge the battery, the charging light flashes orange, if you put a new battery the pc turns on, but even with a new battery the pc does not charge the battery.
          I'm not very good at schematics, but I believe that pub01 has a problem, it does not deliver a strong enough voltage on the gate (UG1_CHG: 6v) of the mosfet PQ026
          I did not find any shorts or resistance dead, the ISL95869HRTZ is well powered at 19v.
          Do you...
          09-10-2023, 07:54 AM
        • ipatch
          dell inspiron 5567 laptop battery lipo WDX0R
          by ipatch
          recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
          1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
          2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
          got the computer...
          04-02-2023, 04:45 PM
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
