E5540 shorting adapter - unusual
  • spleenharvester
    • Mar 2010
    • 921
    Hi all, really odd one here.
    I have this mainboard from an E5540, unknown history but cosmetically in excellent condition. No signs of liquid damage, but slightly melted plastic at one of the HDD posts. Slightly peeled PCB surface at the battery connector, though it didn't appear to be burned.
    It is shorted at +SDC_IN and other connected rails. I thought this would just be a usual case of injecting voltage into the shorted rail and seeing what heats up. Unfortunately, I cannot for the life of me find anything heating up when I do this. The power delivery area of the board does get slightly warm when +19V is injected into this shorted rail at PQ404 legs 5-8, but I cannot identify the source of the heat. PQ401 and PQ402 are not shorted at legs 2 or 3.
    I'm going to lift off PL400 to figure out what side the short is on later, but I suspect it is somewhere on +SDC_IN as there are more components on this line. Anyone got any other tips? I'm really perplexed by this. All I can think is that it's a shorted ceramic cap I haven't yet identified (this is one of those nightmare boards where very little is screenprinted so I don't 100% know for sure where some of these caps are).
    Attached pics, schematics are posted in this thread: https://www.badcaps.net/forum/showthread.php?t=79018
    Thanks in advance
    (Edit, forgot to add - my injection PSU shuts off totally if it's just applied to the DC connectors directly. I find this odd because it's fine when I directly target the rail)
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: E5540 shorting adapter - unusual
    Always measure exact resistance to ground when a short to ground is suspected. And monitor voltage/current on the PSU to know the dissipated power.
    • spleenharvester
      • Mar 2010
      • 921
      Measures 0 ohms to ground when lead resistance is subtracted. I can't remember what the PSU pulled, but it was a substantial amount of current. Unfortunately said PSU just died a death while trying to troubleshoot this board so I can't double check atm.
      • khaahk
        • Dec 2013
        • 816
        • Estonia
        From my service history i have one 5540 with marking of shorted capacitor near PQ404. So just in case the history repeats itself check these two guys.
        • spleenharvester
          • Mar 2010
          • 921
          Interesting you mention that, I'd actually suspected those caps due to proximity to the melted stuff. But they just don't seem to be heating up when voltage is injected.
          • spleenharvester
            • Mar 2010
            • 921
            Okay update, I've removed the two caps closest to the melted area. No dice. More importantly, I've removed PL400 and the short is definitely between there and PQ404. Still nothing heating up when I inject 9V! I'm not 100% sure I have identified all of the other caps on that area correctly though as none of the ceramic caps are screenprinted at all. Any ideas?
            • spleenharvester
              • Mar 2010
              • 921
              FIXED! It was one of the caps on the other side of the board next to hole H37. I noticed a small crack on the side. Not sure why it wasn't heating up when voltage was injected - perhaps an electrical reason someone more knowledgeable than me can fill in on
              Only issue is that I have no idea what cap I need to replace it with as nothing is screenprinted. Any ideas? Pic attached. It's either PC401, PC402, PC414, PC412, PC415, or PC416 on the screenshot posted in the OP.
              EDIT: Sorry, I forgot to add an arrow to the pic. It is the space closest to the connector (next to those other two caps by "H37").
              • spleenharvester
                • Mar 2010
                • 921
                Bump, anyone know what I can replace it with? It looks like it's just a decoupling cap.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  To find the name of the shorted capacitor, you should discover the name of the two neighbor capacitors. Then, the shorted capacitor will be probably the one beside the neighbor capacitors on the schematics too.
                  • KvnTM
                    • May 2018
                    • 434
                    I'd bet it isn't necessary to have on the board because it is next to a small inductor going to gnd. Probably just for EMI reasons.
                    Those grey'ish white components are usually inductors but correct me if I'm wrong though.
                    • spleenharvester
                      • Mar 2010
                      • 921
                      Thanks guys - I'm going to replace it with an X7R 25V 0.1uF ceramic - my reasoning is that this cap seems to be an 0603 package and the only 0603s on this part of the schematic are 0.1uF. Cheers
                      • spleenharvester
                        • Mar 2010
                        • 921
                        So I replaced the cap. Left the system idle on the BIOS screen for an hour while charging - came back and it was dead again. Exactly the same issue, but this time two other decoupling capacitors on that line were shorted. I *think* they were the 22uF caps, and I've had to replace them with several 0.1uFs as I don't have any 22s kicking about. It's alive again now but I'm guessing the same problem is probably just going to happen again?
                        • spleenharvester
                          • Mar 2010
                          • 921
                          Just as a follow up, the system still works fine several months later and no further shorts have occurred.
                          • reessi
                            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                            by reessi
                            Hello:
                            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                            I started on the ACER:
                            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                            10-29-2024, 11:31 AM
                          • Yanleb
                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                            by Yanleb
                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                            D608, good
                            D618 RF101L4S, good (See warning 1 below)
                            D619 RF101L4S, good (See warning 1 below)
                            D865 RF101L4S, shorted (See warning 1 below)
                            IC464 Inverter HA MC74HC1G14, shorted...
                            03-09-2020, 12:00 AM
                          • modtool
                            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                            by modtool
                            Hi to all,
                            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                            04-01-2025, 08:22 AM
                          • BalkanBoy
                            Dead Razer Blade 14 2022, shorted CPU?
                            by BalkanBoy
                            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                            I removed coil and injected 0.7V, it draw around...
                            09-27-2024, 12:44 PM
                          • barry101
                            Apple 820-3662 VCore shorted to ground.
                            by barry101
                            Hi, Would appreciate some help.
                            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                            Get charger light but no fan spin or chime. No liquid damage.
                            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                            06-24-2025, 07:34 AM
