how to confirm if you have a dead SMC/SUPER IO CHIP?
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Guys how do you confirm if you have a dead Super io chip (SMC Chip)?
    Which pins to check if you have a dead Super IO chip?
    How do you confirm?
  • KvnTM
    • May 2018
    • 434
    Re: how to confirm if you have a dead SMC/SUPER IO CHIP?
    SMC (Apple) and Super IO / EC / KBC are completely different things.
    What do you exactly mean? What Chip?
    Nobody is able to help without any information about it.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I think he means kbc on non-apple mobo's.
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        i mean Super IO chip(kbc/ec/)
        • mnciks11
          • Aug 2019
          • 345
          • south Africa
          • rediii
            h???, spurrrn
            • Mar 2018
            • 501
            • somewhere in europe
            most likely it's shorting the 3.3 v-rail to ground. for example, you can check caps near the super-i/o for shorts, sometimes the chip itself will get hot if charger is plugged in or you inject voltage. in some cases, the chip is exploded and looks suspicious under the microscope or in macro mode... other things are to check the pins (via datasheet) and compare the readings/voltage-output. especially lenovo systems with the quadrangular charger and destroyed charging port/charger plug have a bad i/o-chip. in this scenario, the 19 v-rail touch the middle pin and will straightly fry the ic. it's just a bad design by the manufacturer...
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • MORETTIGIAN
              by MORETTIGIAN
              Title:
              Description:
              Procedure performed:
              - Removed backplate
              - Reapplied thermal compound
              - Reassembled card
              09-18-2025, 12:14 PM
            • ongobongo
              Asus ROG Ally - Super IO Chip replacement
              by ongobongo
              anyone here who has experience with replacing the super IO chip of an ROG ally?
              I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
              Ongo
              11-17-2024, 11:27 AM
