As soon as i plug the charger the CPU get extremely hot
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys, I'm diagnosing the Asus PU551LA Rev 2.0, I don't have the schematic. The laptop is dead, not charging, not turning On, as soon as i plug the charger the Cpu get extremely hot, there is a shorted to ground cap near the cpu, and another shorted to ground output coil but I'm not sure if it for the cpu or not.
    Please see attached photos and help guys
  • KvnTM
    • May 2018
    • 434
    Re: As soon as i plug the charger the CPU get extremely hot
    3.3v on PCH present? Take the heatsink off and feel if the smaller die gets hot very fast.
    If so then you have a dead PCH.
    If the cap is shorted then the coil would also be shorted to gnd if they are on the same rail. Should make sense.
    Replace the cap and short should be gone.
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      I don't have any 3.3v, bios chip doesn't have 3.3v, there is no short on the 3.3v rail. Why the CPU is getting hot as soon as charger plugged in, shouldn't it start getting hot as soon as all the power supplies are working?, brother I'm confused here, the laptop is missing 3.3v and the processor is getting hot
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        How do I check 3.3v on the PCH if the 3.3v is missing?
        • piernov
          • Jan 2016
          • 4437
          • France
          As KvnTM said, " Take the heatsink off and feel if the smaller die gets hot very fast."
          • KvnTM
            • May 2018
            • 434
            Originally posted by mnciks11
            I don’t have any 3.3v, bios chip doesn’t have 3.3v, there is no short on the 3.3v rail. Why the CPU is getting hot as soon as charger plugged in, shouldn’t it start getting hot as soon as all the power supplies are working?, brother I’m confused here, the laptop is missing 3.3v and the processor is getting hot
            3.3v and vcore are the two primary high current power rails to the SoC.
            VCore is most likely not present since it is not turning on.
            Other Auxiliary power sources can't deliver enough current to heat it up so badly.
            I sadly can't get a schematic or boardview for this model without paying some shady Russian website.
            Just take the heatsink off and do what I said. Easiest method to tell if you can scrap the board.
            • mnciks11
              • Aug 2019
              • 345
              • south Africa
              Originally posted by piernov
              as kvntm said, " take the heatsink off and feel if the smaller die gets hot very fast."
              yes i did, as soon as i plug the charger, the cpu get extremely hot
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                The soc here has two components-pch+processor-though its soldered as single die. The smaller one is pch and the bigger one is processor as@piernov and Kvntm has explained. You should give a definite answer which die is heating up.
                • KvnTM
                  • May 2018
                  • 434
                  I made an image as explanation for you.
                  Yours may look a little different but there should be 2 chips on the processor package. One is the CPU (Larger, mostly a wider rectangle) and one the PCH (Smaller). Take the heatsink off and put your finger on the PCH while no power is applied.
                  Now plug in your charger while still having the finger on it. If this chip heats up immediately you most likely have a bad PCH.
                  If you don't know what a PCH is:
                  PCH stands for Plattform Controller Hub and replaces the Northbridge and Southbridge into a single chip directly on the processor.
                  Back then North- & Southbridge were two separate chips on the Mainboard. The Northbridge was handling PCI(e) and RAM. The Southbridge was the controller for peripherals (USB, IDE, SATA, .....).
                  They combined those to minimize power draw and improve speed on ultra low voltage processors like the one on your board.
                  If the PCH is bad you would have to replace the whole processor or get a new board. Replacing the processor is not easy and can't be done without a BGA rework station. It does NOT work with an hot air gun!
                  • mnciks11
                    • Aug 2019
                    • 345
                    • south Africa
                    Thank you so much fellows, thanks a million.
                    The PCH is getting hot
                    • KvnTM
                      • May 2018
                      • 434
                      Thats sad news.. You got 2 options now.
                      A: Scrap the board and get a new one
                      B: Replace the CPU
                      • hornylamb
                        • May 2021
                        • Georgia
                        First.. Thanks a lot for explanation and what i was looking for.
                        Could you please let me know. recently i have found in YouTube comments , it say it is not safe to apply thermal paste on PCH. Is it that correct ?
                        because in some of YouTube videos i see somebody put thermal paste on PCH, i guess those people doing mistake.
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 496
                          • somewhere in europe
                          thats not right. you should apply thermal grease on the pch as long as the heatsink is covering it... otherwise a thermal pad would be useful
                          Last edited by piernov; 05-23-2021, 04:08 PM. Reason: remove full quote of previous post
                          • piernov
                            • Jan 2016
                            • 4437
                            • France
                            For U CPUs (CPU and PCH on the same package), there shouldn't be thermal paste on the PCH die, except if there was some originally but that shouldn't be the case.
                            • reessi
                              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                              by reessi
                              Hello:
                              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                              I started on the ACER:
                              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                              10-29-2024, 11:31 AM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                            • flat-earther
                              how to prevent a connected charger from draining battery when not charging?
                              by flat-earther
                              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                              So the battery is backfeeding the charger and being drained.
                              How can I prevent...
                              08-07-2025, 01:04 PM
                            • Johndill
                              Dell Inspiron 7567 LA-D993P odd charger issue
                              by Johndill
                              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                              Here are the tested scenarios:
                              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                              2. With the laptop off, plug in charger (LED says on) & the front charging...
                              11-16-2022, 10:55 PM
                              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                              Narrow VDC applications where the system power source is
                              either the battery pack or the regulated output of the charger.
                              This makes the max voltage to the system equal to the max
                              battery voltage instead of the max adapter voltage. Operating
                              at lower system voltage can improve...
                              11-05-2024, 04:43 PM
