Shorted on board cpu or not
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello my lovely fellows, I have a question for you, how do you confirm if the cpu it self it shorted to ground?
    Sometimes I come across situations where the cpu power rail including gfx will beep when checking capacitors both sides, ground and positive on the beeping mode and give me a value of 000 ~ 002 (beeping mode).
    I uplifted the pwm cpu output coil from the board, the beep stops on the other side but the cpu ceramic caps are still beeping on both sides with the value of 000 ~ 002 on the beeping mode. Anyway the board got the on board cpu and I don't have reballing tools
    Thank you
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Shorted on board cpu or not
    CPU is not shorted.
    Use resistance mode, not continuity mode or diode mode.
    Exact resistance will depend mostly on CPU generation and some other parameters.
    • mo000
      • Nov 2017
      • 276
      • algeria
      Thank you
      desolder the coil and look which side do you have the short ; the built-in cpu with integrated gpu always has that kind of problems because over heating .
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        Originally posted by piernov
        CPU is not shorted.
        How, I've been using the continuity mode all along, from what ranges do I set my multimeter to?
        And Based on the results that I will get from the multimeter, how will i confirm if the CPU is shorted to ground or not?
        • mnciks11
          • Aug 2019
          • 345
          • south Africa
          Based on your method, you use the continuity mode or resistance?
          And how do you interpret the results on the multimeter ?
          • Dumah Brazorf
            • Jun 2013
            • 179
            • Italy
            Cpus/gpus have a low resistance so it's normal the multimeter beeps. Think about it: they work @1-1,5V and draw 20-50-100W. They need a lot of amps so their internal resistance is quite low.
            • iusar
              • Mar 2017
              • 35
              • Hasgard
              do you measuring current to cpu? use laboratory power source 1Vdc.
              do you sense temperature excessive?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Keep it simple, measure impedance on resistance mode. value of 002 or higher is quite normal for onboard cpu/gpu.
                • mnciks11
                  • Aug 2019
                  • 345
                  • south Africa
                  But it shouldn't be that close to ground right, check when I use continuity mode I get 002 is that normal?
                  • mnciks11
                    • Aug 2019
                    • 345
                    • south Africa
                    The whole motherboard it not coming On that my case, I have no lights, I have all the needed volts 19v,3.3v and other bolts but the board it not coming On, and I was suggesting that the on board cpu is shorted since I'm getting 002 on the continuity mode, Coils and caps on the vcore they give me that value even on the gfx power rail
                    • mnciks11
                      • Aug 2019
                      • 345
                      • south Africa
                      Thank you so much brother
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        Check the voltage of the processor 1vdc or 1.2vdc depending on the processor. if you thinks its a shorted processor the voltage will always be 0vdc. Voltage check it first. if you see all the voltage is present you need to check somewhere else the processor don't fail often unless of course if its overheated cheers
                        Never stop LEARNING because life never stops TEACHING!
                        • mnciks11
                          • Aug 2019
                          • 345
                          • south Africa
                          Thank you so much friend but the problem has been solved
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            Hi, how did you solve it?
                            • Oj computer
                              • Dec 2021
                              • 38
                              • Nigeria
                              Hello house
                              Pls how may I rectify processor shorting on e5430 board.
                              When I removed processor, the shorting will stop, and I've used 3 different processor still shorting whenever processor is installed.
                              Pls what can I do as this is.
                              Anyway out pls
                              • mon2
                                • Dec 2019
                                • 14140
                                How are you concluding there is a short ? This many processors cannot be all shorted.
                                Remove all power. Meter in lowest resistance mode.
                                What is the resistance to ground of the power rails for the CPU ? Do note that low voltage rails have low resistance to ground readings. They are NOT shorted in such a case.
                                Post your resistance measurements and where you are taking the measurements.
                                • Oj computer
                                  • Dec 2021
                                  • 38
                                  • Nigeria
                                  OK sir thanks for ur response.
                                  PLs How do I know the CPU power rail.
                                  I'm a beginner sir.
                                  • mon2
                                    • Dec 2019
                                    • 14140
                                    Configure your meter in resistance mode (lowest scale).
                                    Check the rail you report to be shorted with red meter lead on this test point.
                                    Black meter lead to ground (shield is ok).
                                    What is the resistance to ground ? Post the measurement.
                                    CPUs operate at very low voltages like 0v8 and for this reason, their resistance for the power rails are also very low like 4 ohms, etc.
                                    In diode mode on the meter, the rail can appear to be a short.
                                    You can also confirm the resistance to ground for each coil on the logic board. Coils are often large and grey in color with only 2 large solder legs. The power rail(s) for the CPU will be nearby the CPU itself.
                                    • crot69
                                      • Mar 2020
                                      • 61
                                      • Indonesia
                                      But i have laptop with vgfx (onboard) cause laptop always turn on and off. I measured all pin accross cpu power ic and found that gfx_sense always 0v and ohm mode show 0ohm. Is this bad CPU?
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • modtool
                                        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                        by modtool
                                        Hi to all,
                                        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                        04-01-2025, 08:22 AM
                                      • Dylan Jones
                                        MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
                                        by Dylan Jones
                                        I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
                                        I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
                                        06-28-2025, 05:07 PM
                                      • Yanleb
                                        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                        by Yanleb
                                        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                        D608, good
                                        D618 RF101L4S, good (See warning 1 below)
                                        D619 RF101L4S, good (See warning 1 below)
                                        D865 RF101L4S, shorted (See warning 1 below)
                                        IC464 Inverter HA MC74HC1G14, shorted...
                                        03-09-2020, 12:00 AM
