DAY11AMB6E0 three flashes on dc jack
  • luckydip
    • Aug 2016
    • 165
    • uk
    Hi
    HP laptop, no charging light on dc jack when adaptor inserted.When you press the power button, three flashes on jack, apart from that dead. I checked the 3v &5v coils nothing, both missing enable signals on PU11 and PU12. 3VPCU & 5VPCU, 19v present.
    The enable signal S5_ON comes from Super I/O. Checked a few volatges, looks like 3v on pin 11 is missing. Not sure where this comes from, any ideas?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: DAY11AMB6E0 three flashes on dc jack
    SIO pin11 3V comes after switching 3VS5 , what is the voltage on pin 7&8 PU11, PU12 pin8 ? Check on SIO pin 97 ACIN, is the PR211 CLR getting +19V
    • luckydip
      • Aug 2016
      • 165
      • uk
      Originally posted by techtiger
      SIO pin11 3V comes after switching 3VPCU , Check on SIO pin 97 ACIN
      PU11
      pin 7 4.3v
      pin 8 19.6v
      PU12
      pin8 19.6v
      pin 97 ACIN 3v
      I injected the enable signal and both coils had 3v & 5v.
      PR211 19v both sides
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Check SIO pin 67 AD TYPE are you using a original Charger ?
        • luckydip
          • Aug 2016
          • 165
          • uk
          pin 67 0v
          The machine came with no charger but I'm using a hp adaptor which works ok on other pavillions. Is this the issue?
          • luckydip
            • Aug 2016
            • 165
            • uk
            Originally posted by luckydip
            pin 67 0v
            The machine came with no charger but I'm using a hp adaptor which works ok on other hp's. Is this the issue?
            So it looks like the charger is not detected? I've tried another one and the same problem. Do I need to check the jack pin 5 for AD_ID? If no voltage here, is that a faulty jack?
            • piernov
              • Jan 2016
              • 4437
              • France
              DC-in LED blinking 3 times mean the AC adapter is not recognized properly or is not the correct power rating.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Yep Piernov is correct you need to check AD_ID?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  yeah, agree 100%. Faced this on many occasions.
                  • luckydip
                    • Aug 2016
                    • 165
                    • uk
                    AD_ID 0v, ordered new jack - will update once I get it. Thanks guys!
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      If the dc jack looks fine with no apparent damage, then problem may be in the mb.
                      • luckydip
                        • Aug 2016
                        • 165
                        • uk
                        Update - power jack changed and now boots up. But, when I attach the power adaptor I get a white screen before I press the power button. Similarly, I get a white screen when I turn the machine off when power adaptor is attached. So it looks like screen has a direct power line. Should the +3VLCD_CON only come high after the power button is pressed? Apart from that the screen works fine. Any ideas?
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          White screen usually means backlight is on but power to the LCD is off.
                          The backlight enable line should go low when the computer is off.
                          • luckydip
                            • Aug 2016
                            • 165
                            • uk
                            I checked U3 pin44 BL_EN - its low when the machine is off and comes high when i power up.
                            pin 20 PANEL_VCC low then high on power on
                            pin 19 PWMOUT initially 5v then drops to 3v on power on
                            does pin 19 set brightness?
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              Yes, it should be between 0 and 3.3V. Should probably be 0 when the computer is off…
                              • luckydip
                                • Aug 2016
                                • 165
                                • uk
                                Is the next step to change U3 RTD2136R?
                                • Antonynl
                                  HP zbook pwr Jack flashes 8x orange 150w adapter
                                  by Antonynl
                                  I'm stuck with a hp zbook : the charge port flashes white/orange 8 times and than a white light
                                  it has 3.3 and 5v and 19v main power
                                  got 3.3 on onoff switch that gets pulled down by onoff switch but no reaction
                                  Got 1.6v on the middle pin of the power jack.
                                  Using a 150w original hp adapter.
                                  It has suffered minor some water damage
                                  Board DA0XW1MBAI0 REV:1
                                  Any suggestion or hint?
                                  Thanks!!
                                  09-21-2022, 08:10 AM
                                • valvashon
                                  Samsung UN55FH6030CXZA main board USB jack indentification
                                  by valvashon
                                  Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
                                  I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
                                  01-23-2025, 11:17 AM
                                • odie34
                                  Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                  by odie34
                                  I am a hobbyist (not a professional) so please be gentle...
                                  I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                  I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                  02-18-2024, 09:11 AM
                                • dicky96
                                  Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                  by dicky96
                                  Hi guys
                                  I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                  If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                  If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                  03-24-2023, 06:33 AM
                                • paparazzo79
                                  3.5 mm headphone jack missing
                                  by paparazzo79
                                  Hi guys,
                                  I purchased used MSI GE 73 Raider laptop used from a guy.When laptop came home I noticed that there is no "golden circle connector" on the headphoner jack (pic below).
                                  I contacted the seller, he told me like it was there and it probably fell off.
                                  I am not dumb, is he lying to me or it is possible that in the shipping it really fell off?
                                  Oer laptop is missing whole connector.
                                  The headphone jack works normally,I have tested it with headphones....
                                  05-20-2025, 08:48 AM
