Chips with unusual screen printing
  • memorama
    • Oct 2014
    • 11
    • mexico
    Hola alguien pudiera ayudarme con este chip tiene esto en serigrafia T27Y abajo de esto 2234 adjunto fotos del tipo de motherboard y chip en cuestión. gracias
    Originally posted by Google Translate
    Hello, could someone help me with this chip? Do you have this in screen printing T27? Below this is 2234 attached photos of the type of motherboard and chip in question. Thank you
  • khaahk
    • Dec 2013
    • 758
    • Estonia
    Re: Chips with unusual screen printing
    Marking is 2Z..
    most likely RT5041AGQW
    check quanta zhkd for pinout
    • R_J
      • 9535
      I believe the original number is G2234RV1U and the RT5041AGQW could be a sub.
      Looking at other images of this ic shows different letters in the first line (T27Y) also (T312) which are likely date codes.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • ugamazing
        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
        by ugamazing
        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
        08-31-2022, 07:34 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
