Help on HP Stream 14 battery 601 error
  • tbird635
    • Apr 2012
    • 11
    • usa
    Hi All. I have an HP stream 14 that hasn't been plugged in for a year or two. I recently got it out, reinstalled windows. Next step was upgrading the bios to F.06 Rev.A from the website.
    Well, it won't charge. Getting a "601" main battery error.
    So I ordered a new battery, put it in , same issue.
    Tried "disconnecting the AC adapter and battery. Press and hold the power button for 30 seconds. Reconnect power and try starting the notebook again." Did nothing.
    So I took apart the old battery so see what I could find. The cells seem to hold a charge if I apply a 100ma current directly to them. I managed to charge the battery, but I have zero output on the red wires labeled "+" and the black ones labeled "-". From what I've read , some batteries will not output anything without the laptop sending out a signal to the battery turning on the output.
    Anyone have any insight into this? would an older bios kick this back on?
    Anyone have schematics available? Battery and charging schematics or a description of how it works?
    hp stream 14 -z010nr , quanta y08-mb-c , mb part # DA0Y08MBAD0 REV D
    bios F.06 Rev.A
    • 21874
    Re: Help on HP Stream 14 battery 601 error
    Heres a thread with the schematic and boardview https://www.badcaps.net/forum/showthread.php?t=75264 Post #7 and 14
    Have you tried running a battery test https://support.hp.com/gb-en/document/c01443470
    • tbird635
      • Apr 2012
      • 11
      • usa
      That appears to be a Intel Baytrail chipset Stream 13 in that thread, mine's an AMD a4-micro6400T . Would the charging circuit be different?
      • tbird635
        • Apr 2012
        • 11
        • usa
        Tried the battery test, says "battery disconnected ".
        Windows shows the battery life at 100% but the laptop shuts off when I unplug the ac adapter.
        The laptop info screen shows a battery serial number, so It must see the battery. I'm at a loss
        • piernov
          • Jan 2016
          • 4439
          • France
          The "new" battery is supposed to come charged between 20% and 80%. It is supposed to turn on from battery only without the AC adapter. I would say the "new" battery is defective. It is very common, sometimes you even get 2 or 3 bad batteries in a row.
          • tbird635
            • Apr 2012
            • 11
            • usa
            Ok I'll try another battery then. Thanks !
            • razenxd
              How can I charge that battery pack?
              by razenxd
              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
              Now, I have noticed a few things.
              The "dead" battery, while connected to charger and NOT Charging will...
              12-05-2024, 06:11 AM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
            • Klevjetack
              Charge a L19D3PDA battery externally from the laptop
              by Klevjetack
              Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
              03-05-2024, 07:26 AM
            • dclass-pro
              Latitude 3301 not charge battery
              by dclass-pro
              Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
              I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
              I noticed 2 things:
              1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
              2) if I try to turn it on without the battery...
              05-06-2025, 06:19 AM
            • zaurus81
              HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
              by zaurus81
              Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
              WITHOUT BATTERY WITH BATTERY
              PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
              05-06-2025, 09:48 AM
